b16 smokes only in vtec?
Re: b16 smokes only in vtec? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">vtec should not burn oil, your car has a problem.</TD></TR></TABLE>
x 2
x 2
You lose a little oil in VTEC
Re: b16 smokes only in vtec? (nekoabandoned)
Try a leak down test. If your rings are good then depending on how white the smoke is it may be coolant from a headgasket leak or something. Odd's are that the rings are worn and letting a little oil by. As long as there isnt gob's of smoke flying out the back of your car then you're fine.
LSracing94
06-11-2006 02:33 PM
