what i need d to b swap
hello how yall
i have a 94 civic dx with a d15 and i am going to attemt to put a b18 myself and waant to know everything i would need (parts) thank you
Re: what i need d to b swap (skinny1)
block, head, intake manifold. b series fuel rail, tranny, starter, non vtec dizzy, clutch, flywheel, pressure plate, 94-01 integra or 99-00 si axles, 94-01 integra back t bracket, a lot of bolts.
tools=8mm 10mm 12mm 14mm 17mm 19mm and 32mm
and you should be good.
Cool Cool Island Breezes. BOY-EE
1. SEARCH. Trust me, this has been covered ten million times.
2. It will swap about the same as any B series motor
3. b18 what? B18B?A? C1? C5? What year and ecu. What year car?
4. Search. Red button on the top right corner. Find out if you have any SPECIFIC questions after you search.
Re: what i need d to b swap (B serious)
Hey I was going to do this too except I was going to swap a B18A1 (93 + manual transmission) into my EG6. My brother wrecked his car and I wanted to swap his motor into my car. He has basically everything I need because the car just got sideswiped. Will his axles fit or do I need 94-01 Integra axles? What about the motor mounts? He has a hydraulic transmission too. I heard that the B18 is a straight bolt in direct swap but from which year? 90-93 or 94-01? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skinny1 »</TD></TR><TR><TD CLASS="quote">hello how yall
i have a 94 civic dx with a d15 and i am going to attemt to put a b18 myself and waant to know everything i would need (parts) thank you </TD></TR></TABLE>
motor, hydro tranny (or hydro to cable conversion kit), ecu, b-series axles, stock integra motor mounts, back t-bracket (i think), integra shift linkage...all of this comes from a 94-01 integra. anyone add anything if im forgetting something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mypreludeissexy »</TD></TR><TR><TD CLASS="quote">Hey I was going to do this too except I was going to swap a B18A1 (93 + manual transmission) into my EG6. My brother wrecked his car and I wanted to swap his motor into my car. He has basically everything I need because the car just got sideswiped. Will his axles fit or do I need 94-01 Integra axles? What about the motor mounts? He has a hydraulic transmission too. I heard that the B18 is a straight bolt in direct swap but from which year? 90-93 or 94-01? Thanks. </TD></TR></TABLE>
they arent a direct drop in...you have to use b-series motor mounts and a hydro tranny and b-series shift linkage. they are the easiest swap besides the d-series. other than that im pretty sure all the sensors plug in.
Re: what i need d to b swap (slo_hatch)
So the axles, mounts, back t-bracket hydro tranny, and shift linkage won't work if I take them out of my brother's 93 Integra? And when you say B-series axles, any B-Series will work? Like B16, LS, GSR, Type R, etc.?
Please check the link in my sig, I just did that swap, also, please see the image below:
Re: what i need d to b swap (mypreludeissexy)
you can use those axles (90-93 integra) if you are using that tranny, other wise if you used a hydraulic tranny (94-01) you would have to change the seal where the secondary (extension alxe) connects, so your oil doesnt leak out.
