what ecu is everybody using on their gsr ek swap
Re: what ecu is everybody using on their gsr ek swap (kitchale)
So right now I have a 99 GSR ECU which I think is obd2b.
And I am using the 99-00 SI engine harness, in order to make it
work I would need the obd2b into obd2a conversion harness???
Is that correct?
Is that correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale »</TD></TR><TR><TD CLASS="quote">So right now I have a 99 GSR ECU which I think is obd2b.
Is that correct?</TD></TR></TABLE>
Yes, if you want to use a 96-98 GSR ECU.
If you want to use a OBD1 P72 you will need an OBD2b to OBD1 adaptor.
Oh, first I used a 00 GSR ECU, now I'm using a OBD1 P72
OBD1 DEFINATLY better.
I am not using a 96-98 ECU, I am using a 99 GSR ECU.
That would mean I need a obd2b into obd2a harness correct?
Blue Sedan Crew
Re: what ecu is everybody using on their gsr ek swap (12 oz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12 oz. »</TD></TR><TR><TD CLASS="quote">OBD 2 - OBD 1 harness + OBD 1 P72 ECU</TD></TR></TABLE>
this is DEFINTLEY the best way to go, solved all my problems and made the swap so much quicker!
Re: what ecu is everybody using on their gsr ek swap (darkcvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkcvc »</TD></TR><TR><TD CLASS="quote">
if you say so, i used the obd2 gsr ecu and ran fine then went with a obd2-1 harness and a chipped p28 with RT special chip. After i used the chipped ecu i throw code 1 for primary o2 after like 20 mins of driving. gsr ecu no codes.
jdmchickx
10
10-26-2011 06:03 PM
