92-95 sway bar
92-95 sway bar
I have a 92 Civic vx, and i want to put on a front sway bar. I already have a stock rear sway bar.. what can i do, what will fit
Thanks
Thanks
Re: 92-95 sway bar (2.3lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3lcivic »</TD></TR><TR><TD CLASS="quote">I have a 92 Civic vx, and i want to put on front sway bar. I already have a stock rear sway bar.. what can i do, what will fit
Thanks</TD></TR></TABLE>
any upgradable rear sway bar from a 92-95 civic and 94-01 integra will work. just make sure you get some type of brace. the chassis tears with oversized bars.
Re: 92-95 sway bar (philosofy1)
I will leave my stock rear one on for now. What do I need to do to put one on the front? Find a wrecked 92-95 SI and pull all the stuff off of that... anyone make a conversion if you do not have the SI a lower arms
um, he said front sway bar.
You can get a front sway bar from any integra, you want to get the arms as well because your stock civic doesn't have the mounting points. I'm not sure what the arms are called exactly, it might be a-arms?
and they do make mounting brackets, they look awful, just get the arms, its all pretty cheap.
Re: (instrument)
You want the lower control arms of 92-95 civic ex or si 94-? integra. The endlinks mounting brackets and bushings you should be able to source all this for under 100 at a pick and pull it yard.
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">um, he said front sway bar.
HAHA...thanks, i totally miss read that one. talking on the phone and typing doesn't work for me i guess.
they are called lower control arms, and he can pull them off of any 94-01 integra and/or any 92-95 civic ex/si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3lcivic »</TD></TR><TR><TD CLASS="quote"> Find a wrecked 92-95 SI and pull all the stuff off of that... anyone make a conversion if you do not have the SI a lower arms</TD></TR></TABLE>
there are some companies that have a bracket that can bolt up to your existing LCA and sway bar. i know eibach and suspension tecniques has this set up, not sure about the rest though.
Re: (Uchiha_Madara)
thanks but i dont know if i need to do that on my car.. i have a 2.3L accord motor and tranz.. so all the pipes are custon and every thing unbolts where the bar have to go in.... i dont think i will be a pain..... thanks for the heads up
