What DO i Need?????
What DO i Need?????
I have a 98 honda civic DX hatchback Doing a LS swap i have these questions
1. Which Mounts would i need to buy?(stock or aftermarket which ones? give me responese to both options please)
2. Axles- which Yr axles do i have to buy from A 98 ls integra??
3. ECu- which ecu?
4. Also If anyone knows if anyone has a Link to a Step by step or DIY on Engine obd2 Civc Harness Conversion to Fit a LS??
sorry for so many question have to make sure before jumping in
3. ECu- which ecu?
Re: What DO i Need????? (Nicaraguense13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicaraguense13 »</TD></TR><TR><TD CLASS="quote">I have a 98 honda civic DX hatchback Doing a LS swap i have these questions
3. ECu- which ecu?
sorry for so many question have to make sure before jumping in </TD></TR></TABLE>
1. you can get mounts from hasport. dont really know if stock mounts would work.
2. axles somebody else can help you out with that lol
3. if your going lsvtec you can use a p72
3. ECu- which ecu?
Re: What DO i Need????? (ci_v_ic)
1 - i believe the LS tranny upper mount, and the rest is off a 99-00 SI(i THINK, i'm an EG guy), as for the aftermarket, get hasport B-series into EK mounts
2 - ANY B-series axles will do.
3 - use the ECU that corresponds to the motor and the OBD compliance you want to run,
4 - sorry, cant help you there
Re: What DO i Need????? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">3 - use the ECU that corresponds to the motor and the OBD compliance you want to run,</TD></TR></TABLE>
x2, i thought since it was a 98 you would at least spring for the obd-2 setup but hey you never know.
hotcivicsi
10-15-2009 03:04 PM
