What can cause high fuel PSI!?
New User
For some reason I cannot get my b16 to drop below 80 PSI, I'm running a built b16 w/ a p28 chipped, I had to wire the injectors myself, but am pretty sure I did everything right!
What can cause high fuel PSI?
I have a new fuel filter, B&M gauge, STR rail and AEM FPR.
I've been banging my head agianist the wall, and can't figure it out, could someone give me some insight!?
Thanks.
Thanks.
New User
Re: What can cause high fuel PSI!? (SLPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLPR »</TD></TR><TR><TD CLASS="quote">Kinked or clogged return line
FPR not working correctly
You must be reading fuel pressue at the fuel filter with the B&M gauge?</TD></TR></TABLE>
It was 80+ PSI with stock regulator.
I am reading the pressure at the filter, I also have an A/F gauge that is constantly rich, even at idle.
New o2 sensor.
I might have a slight vacumm leak from the t/b to charcoal canister, but that will be resolved soon.
New o2 sensor.
New User
Re: What can cause high fuel PSI!? (976)
I see these damn carbon fiber post stacking up in the civic forum, I'm always here to help others, this is a tech question, I know some more people have some insight beside appearance and good damn carbon fiber bull sheit.
I have never really heard of that one, but try putting every thing back to stock and at one part at a time and that might point to whats wrong.
New User
Re: What can cause high fuel PSI!? (Trooper)
That's a good thought. Maybe I will give it a try this weekend.
I've heard from someone else that a kink in the return fuel line, I will check that as well.
Any other suggestions.
STR fuel rail huh? I bet that is your problem. I believe you have to drill out the hole for the fuel pressure regulator on the fuel rail itself. Aftermarket fuel rails don't usually have that hole drilled so you can use different types of fuel pressure regulators. Check that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Oh ****, I think you're right! </TD></TR></TABLE>
Was that it?
Was that it?
goldegg
07-10-2007 09:00 AM
Jonathan_ED3
11
07-28-2003 04:33 AM
IN VTEC
04-07-2003 11:40 PM
