How to keep Fuel Pressure gauge w/inline fuel filter?
Old 07-27-2003, 03:02 PM
Jonathan_ED3's Avatar
Default How to keep Fuel Pressure gauge w/inline fuel filter?
I screwed up my fuel line so I've got to run an inline fuel filter now, but I cannot figure out how to keep the fuel pressure gauge with it.
I've seen people with the gauge directly on the fuel rail...how would I do that?
Old 07-27-2003, 03:30 PM
Default Re: How to keep Fuel Pressure gauge w/inline fuel filter? (Jonathan_EH)
nobody?
Old 07-27-2003, 05:56 PM
COMplex.'s Avatar
i bought my b&m gauge from inlinefour.com and just screwed it right onto my aem fuel rail. used a little teflon of course and it works mint.
except, dont take it thru those high pressure car washes that to the underside of your car.
i made that mistake and now the plastic/glass cover is gone. lol
god i wish my car didnt suck
Old 07-27-2003, 06:20 PM
Default Re: How to keep Fuel Pressure gauge w/inline fuel filter? (j.fuggi)
well I can' screw it directly into the fuel rail because stock there's already a threaded stud sticking out of the fuel rail.
Is that removeable? If so, then that's all I need to know, otherwise, I've got no clue.
Old 07-27-2003, 06:25 PM
COMplex.'s Avatar
oh, i'm not sure about the stock unit i just flung mine across the garage. lol. speaking of fuel rail, i need to go find some nuts for the top two studs that go thru the back.
Old 07-27-2003, 06:46 PM
Well if you've got your stock one out and won't be out anything if it doesn't, why don't you try to take the stud out of it before I possibly ruin mine?
Old 07-27-2003, 06:53 PM
COMplex.'s Avatar
well. my stock fuel rail is 30 miles away. i have no transportation and i dont know if its still there or if its trashed.
i'll check for you though as soon as i can.
Old 07-27-2003, 06:54 PM
Sprfreek's Avatar
just a suggestion .... i don't know where your running the fuel filter from BUT .... just hollow out your old stock one and put it back in the same spot along with the fuel pressure gauge
Old 07-27-2003, 07:12 PM
Default Re: How to keep Fuel Pressure gauge w/inline fuel filter? (Sprfreek)
I'm not exactly sure what you're suggesting, but reading what you said I think maybe I can just replace the bad section of fuel line, and keep the stock filter and everything.
What do you think? Just replace like a 3-4" section with rubber fuel line hose and clamp it down really good.
Old 07-27-2003, 08:37 PM
Sprfreek's Avatar
ok ok i see what your saying now. what section of fuel line is missing? the section from the stock fuel filter to the fuel rail?
Old 07-28-2003, 04:03 AM
The section from the fuel line that goes up against the firewall to the entrance of the fuel filter. The section from the output of the filter to the fuel rail is just fine.
Old 07-28-2003, 04:33 AM
New User
92sleepR's Avatar
The AEM fuel rail has a port that is a direct fit for the B&M gauge (1/8" NPT)
Projekt_2nr
03-07-2007 08:30 PM
91integraLSVTEC
10-06-2006 04:50 PM
b18cya
04-10-2003 09:24 AM
ek44
04-06-2003 10:37 AM
Quick Reply: How to keep Fuel Pressure gauge w/inline fuel filter?
