What is this?
Old 04-14-2007, 05:12 PM
gotboost562's Avatar
Default What is this?
I saw this sensor hanging down in my engine bay under the intake manifold:
There was a hose running from the intake manifold to the sensor then to the charcoal canister on the fire wall. I unplugged the sensor and there was no check engine light. I left it unplugged and ran the car, there appeared to be no difference with or without it plugged in. What exactly is this sensor and is it needed? Thanks.
-Mike
Old 04-14-2007, 05:16 PM
BADHDRIVER's Avatar
Default Re: What is this? (gotboost562)
search online the honda part no: on it
Old 04-14-2007, 05:19 PM
DohcSide's Avatar
Default Re: What is this? (BADHDRIVER)
madness???!
Old 04-14-2007, 05:31 PM
BADHDRIVER's Avatar
Default Re: What is this? (DohcSide)
no better anwser to is question but to check online with part no:
I am not mad...
Modified by BADHDRIVER at 9:47 AM 4/15/2007
Old 04-14-2007, 05:55 PM
92ehatch's Avatar
that appears to be a firewall mount map sensor. but it would say map assy on it, so you would know if that was it what motor do you have?
Old 04-14-2007, 05:56 PM
Blk00EJ8's Avatar
Default Re:
evap purge solenoid
Old 04-14-2007, 06:55 PM
95ProjectEJ1's Avatar
Default Re: Re: (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">evap purge solenoid</TD></TR></TABLE>
Exactly what i was thinking... lets hope we are right
Old 04-14-2007, 07:07 PM
mikeymcm's Avatar
evap FTW!!
Old 04-14-2007, 07:23 PM
THC07's Avatar
Default Re: (mikeymcm)
winner by a mile. evap purge control soleniod valve
should hook up to the canister and the TB
Old 04-14-2007, 07:49 PM
Default Re: (THC07)
The motor is a JDM ITR in a 96 DX EK. It is running a P28 with a 0bd1 to obd2 jumper harness. Is the solenoid necessary? It was connected via a hose for the manifold to the charcoal canister. What exactly does it do? The part number on the solenoid itself is Denso: 136200-1290 PCS4.
Old 04-14-2007, 08:06 PM
THC07's Avatar
Default Re: (gotboost562)
with obd1 ecu, no you dont have to use it. there will be a code with obd2 ecu. p28
EDIT
wait, you mean obd2 to obd1 right? p28=obd1
... I think it opens to control gas vapors to the canister... or it closes to relase hydrocarbons. ??
Old 04-14-2007, 08:28 PM
Default Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">with obd1 ecu, no you dont have to use it. there will be a code with obd2 ecu. p28
EDIT
... I think it opens to control gas vapors to the canister... or it closes to relase hydrocarbons. ??</TD></TR></TABLE>
yes, obd2 to obd1 via a p28 ecu. If I take it off, do I just plug the outlet on the intake manifold?
Old 04-14-2007, 09:25 PM
THC07's Avatar
yup
4 no vac leaks
Old 04-14-2007, 10:47 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADHDRIVER &raquo;</TD></TR><TR><TD CLASS="quote">the is better anwser to is question but to check online with part no:
I am not mad...</TD></TR></TABLE>
Everything doesn't have a part number stamped on it.
Old 04-14-2007, 11:10 PM
Mandark06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide &raquo;</TD></TR><TR><TD CLASS="quote">madness???!</TD></TR></TABLE>
madness? o.O
THIS! IS! SPARTA!!!!!!!!!!!!!
haha sry...
slowB20ej8
35
01-03-2008 03:10 PM
98jdmek
05-07-2007 10:56 AM
mondo375
01-02-2006 08:52 AM
99fbpem1
06-07-2004 08:27 PM
v-attack
07-16-2003 01:07 PM
Quick Reply: What is this?
