What is this?
I saw this sensor hanging down in my engine bay under the intake manifold:
https://i33.photobucket.com/albums/d...2/DSC02248.jpg There was a hose running from the intake manifold to the sensor then to the charcoal canister on the fire wall. I unplugged the sensor and there was no check engine light. I left it unplugged and ran the car, there appeared to be no difference with or without it plugged in. What exactly is this sensor and is it needed? Thanks. -Mike |
Re: What is this? (gotboost562)
search online the honda part no: on it
Re: What is this? (BADHDRIVER)
madness???!
Re: What is this? (DohcSide)
no better anwser to is question but to check online with part no:
I am not mad... Modified by BADHDRIVER at 9:47 AM 4/15/2007 |
that appears to be a firewall mount map sensor. but it would say map assy on it, so you would know if that was it what motor do you have?
Re:
evap purge solenoid
Re: Re: (Blk00EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">evap purge solenoid</TD></TR></TABLE>
Exactly what i was thinking... lets hope we are right https://honda-tech.com/forums/images/smilies/emthup.gif |
evap FTW!!
Re: (mikeymcm)
winner by a mile. evap purge control soleniod valve https://honda-tech.com/forums/images/smilies/emthup.gif
should hook up to the canister and the TB |
Re: (THC07)
The motor is a JDM ITR in a 96 DX EK. It is running a P28 with a 0bd1 to obd2 jumper harness. Is the solenoid necessary? It was connected via a hose for the manifold to the charcoal canister. What exactly does it do? The part number on the solenoid itself is Denso: 136200-1290 PCS4.
Re: (gotboost562)
with obd1 ecu, no you dont have to use it. there will be a code with obd2 ecu. p28 https://honda-tech.com/forums/images/smilies/emthup.gif
EDIT wait, you mean obd2 to obd1 right? p28=obd1 ... I think it opens to control gas vapors to the canister... or it closes to relase hydrocarbons. ?? |
Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 »</TD></TR><TR><TD CLASS="quote">with obd1 ecu, no you dont have to use it. there will be a code with obd2 ecu. p28 https://honda-tech.com/forums/images/smilies/emthup.gif
EDIT wait, you mean obd2 to obd1 right? p28=obd1 ... I think it opens to control gas vapors to the canister... or it closes to relase hydrocarbons. ??</TD></TR></TABLE> yes, obd2 to obd1 via a p28 ecu. If I take it off, do I just plug the outlet on the intake manifold? |
Re: (gotboost562)
yup
4 no vac leaks |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADHDRIVER »</TD></TR><TR><TD CLASS="quote">the is better anwser to is question but to check online with part no:
I am not mad...</TD></TR></TABLE> Everything doesn't have a part number stamped on it. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcSide »</TD></TR><TR><TD CLASS="quote">madness???!</TD></TR></TABLE>
madness? o.O THIS! IS! SPARTA!!!!!!!!!!!!! haha sry... |
