want to get rid of cruise control
New User
i need to know how to get the line from the throttle out from the fire wall and what to do w/ the harness that goes to the cruise control itself and what will happen to the ecu? will a CEL come on?
New User
Re: want to get rid of cruise control (clean)
The cruise control throttle cable is directly attached to the gas pedal, you need to unhook it from there and feed it out from the inside. The harness stays, you will not get a CEL, the crusie control is independant of the other operating systems.
New User
Re: want to get rid of cruise control (Guardson3r3)
it's a 97 if you want it, you might have to get more tubing cause the honda dealers told me to hook my boost gauge to that but didnt reaqlize there was a valve before the line so it only worked when cruise was on and set. if you want it sweet, also does anyone know if i can put my boost gauge to the spot where the cruise line came off the manifold? i'm pretty sure i can just want to make sure
