VX wiring??'s OBD1 help please need to know.
I have a 88 CRX that I am putting a b16a2 obd1 in. I installed wiring from a 95 GSR (for the interior) and I have a 93 Civic VX but I understand the VX wiring has a five wire Oxygen sensor.
So my question is what should i do. Will the Oxygen Sensor work or will I need to get a different Oxygen sensor? Or can I just disconnect a wire?
Re: VX wiring??'s OBD1 help please need to know. (Ignitecivic)
Well I will be running a b16a2 converted to obd1. I am still learning the different ECU's but was told to get a p28 and use Hondata on it. Like i said I'm still learning here. lol.
The only wire you have to worry about is the 12v switched, on the VX ECU it's in a different spot. You can move it at the ECU or find another 12v switched source like the main relay plug...
https://honda-tech.com/zerothread?id=919292]
http://www.hondaswap.com/forum...87721
I've done both.
I've done both.
ncrx1
04-07-2003 05:16 PM
