Need some help with civic vx wiring. Tried Search.
Hello,
I've tried using the search function and I'm looking for people who have worked on vx model civics. I'm an ef guy and not so knowledgeable about eg's. I'm posting for a friend who owns a 93 Civic VX. He would like to swap his engine out either for a d16z6 or b series motor.
My question is regarding wiring. Is the P28 simply plug and play or are there some wires that need to be added. Also I understand that the 5 wire 02 sensor must be changed out for a 4 wire sensor.
Other than that, is there anything else to be concerned about swapping into a vx?
Thanks for the help.
Re: Need some help with civic vx wiring. Tried Search. (piscorpio)
well.... VX already has vtec. Unless your running a DOHC motor then you wont need a knock sensor or if you plan on turbo/FI then you will need that knock sensor. basically as long as its OBDI harness then it is plug and play.
Re: Need some help with civic vx wiring. Tried Search. (ncrx1)
if u are plannin to run a obd1 swap its plug and play and wont need any extra wires, because vx civic comes wth vtec, u can also use the p28 or p72 obd1 ecu, it just plugs in and everything bolts on
Re: Need some help with civic vx wiring. Tried Search. (TheTruth709)
Question, you say you can use the p28 ecu, what does the VX come with? I was wondering if I would have to get a new one for Hondata purposes.
dwnthehatch
09-01-2013 07:21 PM
dremmel
02-17-2004 08:24 PM
2muchPSI
02-23-2003 09:15 AM
