VTEC engages at 6000 instead of 5500?
Old 08-01-2009, 03:38 AM
jkalex05's Avatar
Default VTEC engages at 6000 instead of 5500?
I have usdm b16a2 swap and the previous owner told me it has a type R ecu, do you think thats whats causing the higher vtec engagement?
Should I put a b16a2 usdm ecu in it?
Old 08-01-2009, 05:16 AM
EG6KILIN's Avatar
Default Re: VTEC engages at 6000 instead of 5500?
change the oil you could be low on oil also correct me if im wrong!
Old 08-07-2009, 01:02 PM
jkalex05's Avatar
Apprently I have a Type R B17 P73 ECU on a usdm b16a2
Old 08-07-2009, 01:10 PM
happyabortion's Avatar
b17? thats a 92-93 da integra Gsr. What ecu exactly do you have in there? read the stamp on it.
also obd1-or obd2? more details would help
Old 08-07-2009, 01:32 PM
Thizzed Out's Avatar
chipped ECU perhaps?
Old 08-07-2009, 01:33 PM
if your to low on oil, vtec wouldn't engage at all.
Old 08-07-2009, 01:34 PM
kaiba's Avatar
Or it could be that your tachometer is off.
Old 08-07-2009, 05:01 PM
jkalex05's Avatar
Sorry its a B18 Type R ECU, code P73.
Old 08-07-2009, 05:59 PM
b20beast83's Avatar
x2
Meatwad99Si's Avatar
Wait what is it suppose to engage at on say a 99 si with an stock b16a2?
Old 08-07-2009, 06:14 PM
Resident Gearhead
BryanM.'s Avatar
Originally Posted by b20beast83
x2
x3
Definite possibility.
Old 08-08-2009, 01:12 PM
jkalex05's Avatar
Im preety sure my tach isn't off. Doesn't a b18 TypeR redline at 8400 and vtec engages at 6k?
Old 08-08-2009, 07:18 PM
.hawaii's Avatar
my vtec is supposed pop at 5500, ran my friends chipped type r ecu once, he said vtec pops @ 6
Old 08-09-2009, 07:53 AM
Jimster480's Avatar
I think VTEC is 6 on ITR's. Look here.
B18C5
VTEC
Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
Displacement: 1,797 cc (109.7 cu in)
Compression: 10.6:1
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Power: 195 hp (145 kW) @ 8200 rpm & 130 ft·lbf (180 N·m) @ 7500 rpm
Transmission: S80 w/LSD
Vtec engagement @ 6,000 rpm
jollyhonda
07-08-2017 07:15 PM
ek4u2nv
02-25-2008 09:18 PM
JeffBro
10-09-2005 01:50 PM
Qwikrex
18
12-06-2002 06:43 AM
B18C-RnVA
05-11-2002 05:19 AM
Quick Reply: VTEC engages at 6000 instead of 5500?
