Which VSS will work? D-series.
I need a VSS for my D16y7 and wondering what all will work. I had a GSR VSS laying around but it didn't plug into the harness. Will any, all years, VSS from a D-series Civic work?
Re: Which VSS will work? D-series. (cheesee)
Why wont the GSR one plug into the harness? They should all be 3-pin connectors. Some are vertical while others are horizontal on a connecter support bracket. They should pretty much all be interchangeable.
Re: Which VSS will work? D-series. (Slurp56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 »</TD></TR><TR><TD CLASS="quote">Why wont the GSR one plug into the harness? They should all be 3-pin connectors. Some are vertical while others are horizontal on a connecter support bracket. They should pretty much all be interchangeable.</TD></TR></TABLE>
No idea, samething happen to when we swapped agsr into my friend 99 coupe. used civic harness and the vss clip wouldnt plug into the vss. had to use a dseries one and it worked.
Were the connectors the same style? They should all be a 3 pin connector.
Sometime when you unplug them from the wire harness, the plastic insert (and sometimes the rubber weather seal) from the connector will stay inside the sensor. You can remove that with a pair of needle nose pliers. Typically the wire harness plug feels like it should go in, but it just wont snap into position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 »</TD></TR><TR><TD CLASS="quote">Were the connectors the same style? They should all be a 3 pin connector.
Sometime when you unplug them from the wire harness, the plastic insert (and sometimes the rubber weather seal) from the connector will stay inside the sensor. You can remove that with a pair of needle nose pliers. Typically the wire harness plug feels like it should go in, but it just wont snap into position.</TD></TR></TABLE>
Looks the same as the plug. I mean samething happened with my friend so I guess it doesn't work.
boomersz
03-16-2007 06:09 PM
Civic138
04-04-2005 03:56 PM
