Valve Adjustment?
Valve Adjustment?
I need to get my valves adjusted. Is it a DIY project or not. I taken apart alomost everything on my car even taken off the valve cover just never touched anything internal before. How do I adjust the valves, What tools do I need and all that good stuff.
Thanks
Thanks
Re: Valve Adjustment? (revhigh96)
you need a 10mm wrench, a flat head screwdriver, a set of feeler gauges, and a manual to tell you the exact tolerances of clearance for the valves... it is not too difficult, but definately A PAIN IN THE BACK!
Well you'll need a 19mm (I think.. maybe 17mm) for the crankshaft pulley bolt too...
It's kind of a bitch but it's easy as long as you follow procedure and take your time...
If you search I'm sure there's a thread on procedure.
Guest
Posts: n/a
Re: Valve Adjustment? (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">you need a 10mm wrench, a flat head screwdriver, a set of feeler gauges, and a manual to tell you the exact tolerances of clearance for the valves... it is not too difficult, but definately A PAIN IN THE BACK! </TD></TR></TABLE>.. get on ur knees
Make sure you turn your crankshaft pulley to tdc on your #1 piston. Adjsut #1. Then turn it 90 degrees counter clockwise and adjust #3. Another 90 then #2. One more 90 then #4.
Re: (jaxle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaxle »</TD></TR><TR><TD CLASS="quote">im planning on doing this tuesday, or atleast starting on it and finishing wed/thur, im probably going to do a howto on it with pics.</TD></TR></TABLE>
for b18c : http://www.c-speedracing.com/h...t.php
make your own tool by bending/hammering a standard 10mm wrench into an "S" shape. heat it first
Thanks for all the replies looks like its not too hard to do I just have to take my time. Thanks Turbo E for posting the link. The link is great with lots of pics!
zach1288
45
04-17-2007 06:40 PM
