Valves
Old Aug 5, 2005 | 06:28 AM
Baron55's Avatar
Default Valves
How do i tell if I have bent valves or need a valve adjustment?
Old Aug 5, 2005 | 06:31 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Valves (Baron55)
Bent valves are usually very easy to tell. Your motor won't idle very well at all, and depending on the severity, it might not even run. A valve adjustment should be done regularly every 30K miles about, or after any headwork.
You might hear "valve tap" or clicking if your valves are loose. If you do a leakdown test, you might get some release in the valve area if they are loose as well.
Old Aug 9, 2005 | 02:03 PM
Baron55's Avatar
About how much is it for a valve adjustment?
Old Aug 9, 2005 | 02:30 PM
PLAGUED_DB7's Avatar
Default Re: (Baron55)
fees vary..from like 80-150..make sure that where ever you take it the engine is cool...you cant adjust hot valves
Old Aug 9, 2005 | 03:14 PM
Baron55's Avatar
thats for the entire job?
Old Aug 9, 2005 | 03:27 PM
jasonw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">thats for the entire job?</TD></TR></TABLE>yes
russianswty
Oct 22, 2006 06:15 AM
VTECcnIT
Nov 9, 2005 05:43 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
sneakychaos
Sep 9, 2002 05:48 PM
