Turn signal problems HELP PLEASE!!!
Old 09-01-2002, 08:29 PM
CivicTuneR95's Avatar
Default Turn signal problems HELP PLEASE!!!
Ok heres my deal....
For about a month My pass. side blinker has been blinkign fast Well, changed the bulbs and it wasnt that, Now this evening after some cruising around and so, The right Blinker light Stayed on While the head lights were on. and I would push up on the Blinker **** And no passenger side blinker... Now if I turn my head lights off, and USe the blinker it will work as soon as the Head lights go on The blinker light stays on and it wont work... WHAT DO I DO!!! PLEASE HELP!
Thanx in Advance
Old 09-01-2002, 08:50 PM
IdotheSHOCKER's Avatar
Default Re: Turn signal problems HELP PLEASE!!! (CivicTuneR95)
Did you change the bulb out recently and is it the right size??? Any electrical changes or wiring to the car recently??
I did reversed bulbs on my girls Accord once and when you step on the brakes the interior lights would come on and the third brake light would stay on when she drove.....
She loved me even more for that.
Old 09-01-2002, 10:04 PM
TheIntegraGuy's Avatar
Default Re: Turn signal problems HELP PLEASE!!! (EGB18hatch)
Take the wires apart and do a voltage test...See what wires are going to what terminal and figure it out from there...It shouldnt be that hard..
Old 09-01-2002, 10:38 PM
sirminder's Avatar
LOL, oh man thats a classic LOL
Old 09-02-2002, 12:03 AM
TeamVixiV's Avatar
hey i got the answer to your question, this happened to me too when i tried to give my car fast blinker, put your wires back to normal and then change your flashes that is located underneath your steering wheel, it is a big black thing. and if you still want your fast blinker then go to jdmfan.com and click on technical and then go to making a rapid flasher, i did mine like this and it is much better than crossing the wires cause you can switch the flashers in a matter of seconds when needed, hope that helps
Old 09-02-2002, 03:08 AM
kwil666's Avatar
Default Re: Turn signal problems HELP PLEASE!!! (TeamVixiV)
First check all the bulbs to make sure they are the right ones. My friends hatch was doing something like your saying and I checked the bulbs and didnt find anything. Two days later checked them again and found out that one bulb was the wrong one, replaced that one with the right one and everything was bad.
Keith
ef_cowboy
03-08-2013 04:16 PM
tantrumcrx
05-12-2010 08:19 PM
smurf357
07-20-2008 02:33 PM
Killtodie
Honda Civic (2001 - 2005)
06-27-2008 03:46 PM
bmxer
02-02-2008 07:00 PM
Quick Reply: Turn signal problems HELP PLEASE!!!
