turbo in a mini-me ?
I was wondering if anyone can give me info on putting turbo on a mini-me head swap. My set up is D15b7 Block, d16z6 vtec head and tranny. I heard aslong as I lower the compression to 9.5:1 and push 6 psi I should be in the safe zone. I was wondering if theres a way i can push 10:1 compression w/ a safe psi. Also what turbo should I use?
Re: turbo in a mini-me ? (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">tuning is very very important. you can boost a higher compression engine as long as you have great tuning. </TD></TR></TABLE>
i am boosting my mini me with 8psi without lowering compression....I am burning my own chip for my ecu using a program called ghettodyne...if you have some good tuning you will still be in the "safe zone" under boost
Re: turbo in a mini-me ? (dan89crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi »</TD></TR><TR><TD CLASS="quote">
i am boosting my mini me with 8psi without lowering compression....I am burning my own chip for my ecu using a program called ghettodyne...if you have some good tuning you will still be in the "safe zone" under boost</TD></TR></TABLE>
I was just wondering which block did you use to put the vtec head on and also which vtec head did you use? What size turbo did you use and i was wondering if you had to do anything else to your motor to get it to run on 8psi ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote"><U>tuning is very very important.</U> you can boost a higher compression engine as long as you have great tuning. </TD></TR></TABLE>
Re: turbo in a mini-me ? (simplypinoyy)
wasup man I see your from Groton, you need to talk to Carlos A. He is the prez of Dream works Black EJ2 he will tell you everything you need to know. He lives accrose the street from applebees in the Navy housing Apt.s There shoudl be a few hatch backs his Black Coupe on white rims hes Apt. is thru the far left door up the stairs on the top floor to the left, Tell him EJ sent you to get info
Re: turbo in a mini-me ? (CivicSiRracer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 »</TD></TR><TR><TD CLASS="quote">wasup man I see your from Groton, you need to talk to Carlos A. He is the prez of Dream works Black EJ2 he will tell you everything you need to know. He lives accrose the street from applebees in the Navy housing Apt.s There shoudl be a few hatch backs his Black Coupe on white rims hes Apt. is thru the far left door up the stairs on the top floor to the left, Tell him EJ sent you to get info </TD></TR></TABLE>
invasion of privacy much?
josh tavares
13
06-14-2008 04:04 AM
