Turbo D16Z6 or D16y8 or D17a2
Turbo D16Z6 or D16y8 or D17a2 HELP!!!!!!!!!!!!!!!!!!!!1
I am gonna be buyin a SOHC Vtec motor within the next 2 weeks and i am trying to figure which engine best fit my needs. Help me choose between the
1) D16Z6-obd-1
2) D16Y8-obd-2
3) D17a2-obd-3 (is this possible?)
I am gonna turbo one of the three motors above, which of the three wil be better. Some people on HT told me that obd 3-to-obd 1 is not possible and the d17a2 wont fit anyway, is that true? If OBD-3 to OBD-1 is possible, will it require major modification? Thank you .
[Modified by Be2g0, 1:01 AM 1/17/2003]
1) D16Z6-obd-1
2) D16Y8-obd-2
Re: Turbo D16Z6 or D16y8 or D17a2 (thehatchninja)
I'd go with the Y8 and convert it to OBD1, or just swap the head to another D series.
What kind of condition is the long block in? How much are you asking?
Re: Turbo D16Z6 or D16y8 or D17a2 (ImGone)
why would you recomend the y8? just wondering cuz im choosng between the z6 and y8, but im thinking the z6 will be easier.
Former Moderator
Re: Turbo D16Z6 or D16y8 or D17a2 (4g4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4me »</TD></TR><TR><TD CLASS="quote">y8 has a better intake manifold, larger ports, and by theory-better head geometry.</TD></TR></TABLE>
Y8 head does not flow as well as the Z6 head.
Re: Turbo D16Z6 or D16y8 or D17a2 (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Y8 head does not flow as well as the Z6 head.</TD></TR></TABLE>
werd.
use the z6, or the a6. depending on if you want vtec or not
werd.
Re: Turbo D16Z6 or D16y8 or D17a2 (Zer0DazE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE »</TD></TR><TR><TD CLASS="quote">use the z6, or the a6. depending on if you want vtec or not</TD></TR></TABLE>
werd.
werd.
Re: Turbo D16Z6 or D16y8 or D17a2 (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">D16y8 127 hp vtec, when boosted around 8 psi they can make up to around 200hp depending on the car.</TD></TR></TABLE>
so it depends on the chassis how much power it makes?
be professional
Re: Turbo D16Z6 or D16y8 or D17a2 HELP!!!!!!!!!!!!!!!!!!!!1 (Be2g0)
No such thing as OBD-3. The D17A2 cannot be turbocharged easily anyway because of it's returnless fuel system.
D16Z6 with Y8 intake manifold
Re: Turbo D16Z6 or D16y8 or D17a2 (BCRUZ)
Well if u have a 4 door ex with a d16y8 or if u have a hatch vx with a d16y8 the hatch will be faster and lighter. it would be faster in a lighter car im sayin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">Well if u have a 4 door ex with a d16y8 or if u have a hatch vx with a d16y8 the hatch will be faster and lighter. it would be faster in a lighter car im sayin.</TD></TR></TABLE>so since its lighter, it makes more horsepower?
Re: Turbo D16Z6 or D16y8 or D17a2 HELP!!!!!!!!!!!!!!!!!!!!1 (Targa250R)
i was under the impression that the y8 head has slightly higher compression thus making it worse for turbocharging safely. the z6 would be best; already obd-1, abundant, and large aftermarket support. although you would be more likely to find a low milage y8 than a z6. go z though, it'll be better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">D16y8 127 hp vtec, when boosted around 8 psi they can make up to around 200hp <u>depending on the car</u>.</TD></TR></TABLE>
you said the power will vary depending on the car/chassis, not the speed, you said nothing about speed, we all know about power to weight ratios.
Re: Turbo D16Z6 or D16y8 or D17a2 HELP!!!!!!!!!!!!!!!!!!!!1 (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic »</TD></TR><TR><TD CLASS="quote">i was under the impression that the y8 head has slightly higher compression thus making it worse for turbocharging safely. the z6 would be best; already obd-1, abundant, and large aftermarket support. although you would be more likely to find a low milage y8 than a z6. go z though, it'll be better</TD></TR></TABLE>
the y8 head doesnt flow as well as the z6.. the ports are not equal size, they are disigned to help swirl and to promote fuel economy... theres more too it than that.. but i dont feel like typing it.
95EXcivicsleeper
32
06-24-2004 01:15 PM
ATS*VEEE
20
11-03-2002 09:57 PM
130hp
11
08-09-2002 03:32 AM
