Troubleshooting 92 SI b18c1
I've searched a bit, but haven't really found anything similar to my friends problem. This was a car running fine untill awhile ago.
1992 Civic SI 1994 USDM b18c1 with P72 (skunk 2 manifold)
The car cranks but doesn't start.
Compression checks fine across the board.
Replaced Distributor.
It has both Fuel and a Spark.
Fuel Pump/Fuel Filter/Fuel Pressure Regulator Replaced.
Changed Spark Plugs
Replaced Spark Plug Wires.
Timing was checked while it was running and it was fine.
I still continue to have the same problem.
Any idea's or fixes for similar issues would be greatly appreciated. Thanks Guys.
Changed Spark Plugs
Re: Troubleshooting 92 SI b18c1 (FredoTheChimp)
You guys put the dizzy on right, right? And is the rotor on secure? I would check those 2, other then that no clue.
How long did it run with the Skunk2 and the p72?
Re: Troubleshooting 92 SI b18c1 (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You guys put the dizzy on right, right? And is the rotor on secure? I would check those 2, other then that no clue.
How long did it run with the Skunk2 and the p72?</TD></TR></TABLE>
Yeah distributor is on right and the rotor. Ill have to ask him how long he was running on the skunk 2 with the p72
