Trany tips?
Old 05-04-2012, 09:54 PM
jrleffel1's Avatar
Default Trany tips?
I have a 94 del sol with a b18a1 in it. It has a 5 speed in it. My question is, is there an easier way to add trans fluid other then using a funnel with a long tube? It's very time consuming to do it this way and seems as if I waste more fluid spilling out then what goes in the trans. Tips or ticks would be greatly appriciated.
Old 05-04-2012, 10:01 PM
MySickSi's Avatar
Default Re: Trany tips?
Your adding it threw the speed sensor right? It shouldnt.be hard or time consuming at all
Old 05-04-2012, 10:55 PM
jbpnoman's Avatar
If you use the proper fill hole, you can easily fit a small tube into the transmission through that hole, with a funnel on top. I use a funnel with a cut off valve built in (like, $5 at Autozone) and spillage still happens (that's how you know it's full) but it's a minor thing.
If you're using a long funnel and filling through the VSS hole, how the hell are you spilling ANYTHING?
SeanK325
06-03-2010 10:42 AM
luv2boost
08-08-2007 10:06 PM
EG_Civic_Si
02-13-2006 04:11 PM
Re3irth
12
09-01-2004 02:58 PM
InjectedSS
12-19-2002 04:52 AM
Quick Reply: Trany tips?
