Transmition oil change
Old 10-10-2003, 11:49 AM
Jaydeep's Avatar
Default Transmition oil change
Can someone help me where would be that bolt where you take out oil and what size is it. I know it is on left side but I am not sure.
Oh my car is 2000 civic ex AUTO transmition
please help thanks
Old 10-10-2003, 11:51 AM
goodbyegti's Avatar
if you do a search you will find a picture that mr bone posted a litlle while ago showing the exact location
Old 10-10-2003, 11:52 AM
Spade's Avatar
Default Re: Transmition oil change (Jaydeep)
It is the lowest one on the tranny. Left side in the back from the front of the car
Old 10-10-2003, 01:36 PM
RSZero1's Avatar
Default Re: Transmition oil change (Spade)
What he said
Old 10-10-2003, 10:05 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: (goodbyegti)
pic is for a manual tranny..........
Old 10-11-2003, 01:10 AM
super laubo's Avatar
not sure about an auto, but for manuals you can skip out on the fill plug. unplug the VSS (vechicle speed sensor) and fill it from the top.
Old 10-11-2003, 03:51 AM
goodbyegti's Avatar
...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... if you get a simple funnel with a flexible hose it is dead easy to use the fill plug, just gets a little messy if you're not careful.
Old 10-11-2003, 04:42 AM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">Oh my car is 2000 civic ex AUTO transmition
please help thanks</TD></TR></TABLE>
Looks like he said auto to me...in which case I have no idea.
Unless, it's like a lot of the other cars out there, the plug is on the bottom, facing the street.
Does it have a filter too? If so, replace that. That could be inside the pan.
So you'll probably need a new gasket after removing the pan, to get to the filter.
Old 10-11-2003, 08:12 AM
FMIDRC Racer's Avatar
look in the bottem of the tranny. you should see a bolt that looks like it kinda has a flat end and it has i beleive a allen key head. be sure to only use honda atf to fill it up again unless you like a slipping trans.
Old 10-11-2003, 09:27 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: Transmition oil change (Eee Pee)
EP, the Honda auto trannys have a NON serviceable filter. It can only be replaced upon a complete rebuild.
#1 reason you'll never see a Honda with a automatic in my driveway.
Old 10-11-2003, 11:56 AM
solo2slocivic's Avatar
autos use the same style drain plug as manuals and you refill then through the dip stick hole and the tranny holds 2.9 quarts of honda atf-z1
Old 10-11-2003, 12:45 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodbyegti &raquo;</TD></TR><TR><TD CLASS="quote">...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... </TD></TR></TABLE>
No need to measure. B series uses 2.3 quarts. Even 2 will work perfectly fine. D series will be fine on 2.
**** the fill level bolt.
Old 10-12-2003, 02:45 PM
goodbyegti's Avatar
if you have a decent funnel with a flexible hose it is dead easy to use the filler hole, i read a little on here before i did it and everyone was like"yeah its well hard to use the filler hole etc.. use the vss hole" but when i came to do it i had no problems at all..
Old 10-12-2003, 03:31 PM
It doesn't matter. Do whatever the **** comes easier...
Peter_404_21
12-30-2008 08:54 PM
ejpogi1925
10-02-2008 03:08 PM
Rex89
16
01-02-2007 06:24 PM
killakoupe
09-15-2006 09:16 PM
EJ8 GSR-T
09-04-2005 11:59 AM
Quick Reply: Transmition oil change
