Transmition oil change
Can someone help me where would be that bolt where you take out oil and what size is it. I know it is on left side but I am not sure.
Oh my car is 2000 civic ex AUTO transmition please help thanks |
if you do a search you will find a picture that mr bone posted a litlle while ago showing the exact location
Re: Transmition oil change (Jaydeep)
It is the lowest one on the tranny. Left side in the back from the front of the car
Re: Transmition oil change (Spade)
What he said
Re: (goodbyegti)
not sure about an auto, but for manuals you can skip out on the fill plug. unplug the VSS (vechicle speed sensor) and fill it from the top.
...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... if you get a simple funnel with a flexible hose it is dead easy to use the fill plug, just gets a little messy if you're not careful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep »</TD></TR><TR><TD CLASS="quote">Oh my car is 2000 civic ex AUTO transmition
please help thanks</TD></TR></TABLE> Looks like he said auto to me...in which case I have no idea. Unless, it's like a lot of the other cars out there, the plug is on the bottom, facing the street. Does it have a filter too? If so, replace that. That could be inside the pan. So you'll probably need a new gasket after removing the pan, to get to the filter. |
look in the bottem of the tranny. you should see a bolt that looks like it kinda has a flat end and it has i beleive a allen key head. be sure to only use honda atf to fill it up again unless you like a slipping trans.
Re: Transmition oil change (Eee Pee)
EP, the Honda auto trannys have a NON serviceable filter. It can only be replaced upon a complete rebuild.
#1 reason you'll never see a Honda with a automatic in my driveway. |
autos use the same style drain plug as manuals and you refill then through the dip stick hole and the tranny holds 2.9 quarts of honda atf-z1 https://honda-tech.com/forums/images.../h-emblem4.gif https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (goodbyegti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goodbyegti »</TD></TR><TR><TD CLASS="quote">...but i guess you'll want to remove the fill plug anyway to see when it overflows unless measure the amount of fluid you put in... </TD></TR></TABLE>
No need to measure. B series uses 2.3 quarts. Even 2 will work perfectly fine. D series will be fine on 2. Fuck the fill level bolt. |
if you have a decent funnel with a flexible hose it is dead easy to use the filler hole, i read a little on here before i did it and everyone was like"yeah its well hard to use the filler hole etc.. use the vss hole" but when i came to do it i had no problems at all..
Re: (goodbyegti)
It doesn't matter. Do whatever the fuck comes easier...
