3rd gear problems??
Old Jun 16, 2003 | 08:30 AM
91hatchcivic's Avatar
Default 3rd gear problems??
when i shift into 3rd , it makes a grinding noise, like metal on metal, but if i shift pretty slow, it wont really do it, but i have to do it really slow. Whats the problem, and how do i fix it??
Old Jun 16, 2003 | 08:47 AM
Dgr8wun's Avatar
Default Re: 3rd gear problems?? (91hatchcivic)
you have bad synchros and u need to replace them...
Old Jun 16, 2003 | 08:50 AM
Default Re: 3rd gear problems?? (Dgr8wun)
how much do the syncros cost?
Old Jun 16, 2003 | 11:39 AM
Ottoman's Avatar
before my car crashed, i replaced all the synchro's for 320 bux... felt like a brand new gearbox... so much so that the clutch started slipping for the first time....
synchro's aren't that pricey... but the labor may rob u...
Old Jun 16, 2003 | 11:40 AM
Ivan's Avatar
senior gold member
yup sounds like the infamous 3rd gear grind. what kind of car do you drive? by your sn I would say a 91 civic?
Old Jun 16, 2003 | 12:28 PM
Dgr8wun's Avatar
synchors run from 80-200 depending on the tranny
Old Jun 17, 2003 | 05:02 PM
superls92's Avatar
where can you get syncros from any were on the internet??
Old Jun 17, 2003 | 05:18 PM
Default Re: 3rd gear problems?? (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">yup sounds like the infamous 3rd gear grind. what kind of car do you drive? by your sn I would say a 91 civic? </TD></TR></TABLE>
had a 91civic, now i have a 89si with b16 and ys1 tranny
Old Jun 17, 2003 | 06:10 PM
Mostec_EG's Avatar
I had the same problem with my b16 tranny. Only my problem was worse, sometimes even 4th gear grinds also. When I asked around, some people told me to change the tranny oil using Honda MTF. As a last desperate move, I changed the MTF. The tranny actually got better gradually. About a week after I changed the tranny oil it doesn't grinds anymore.
Old Jun 17, 2003 | 06:45 PM
Default Re: 3rd gear problems?? (Mostec_EG)
where do u get this honda mtf?
Old Jun 18, 2003 | 08:06 AM
projecthybrid04's Avatar
i have a ys1 tranny too and my 3rd gear does that same thing
Old Jun 18, 2003 | 11:34 AM
976's Avatar
976
New User
Default Re: 3rd gear problems?? (projecthybrid04)
Must just be the ys1 and s1 trannys.
I'm going to try fully synthetic oil, and redline MTL, right now it won't grind in third under 2,200rpms. I do have a spoon drain plug w/ magnetic as well.
Old Jun 18, 2003 | 11:40 AM
Malgerus's Avatar
Default Re: 3rd gear problems?? (w00t!)
I wouldn't try Redline... I've heard too many bad things about it... try GM Syncromesh synthetic.... heard nothing but good things about it.
Old Jun 18, 2003 | 11:47 AM
Default Re: 3rd gear problems?? (Mr. S)
so should i get the honda mtf or gm syncromesh?
Old Jun 18, 2003 | 02:08 PM
eg6h8k's Avatar
what do synchros look like..are they the gold/yellowish looking gears in the tranny..? doesnt look like u can order them from majestic honda..?
Old Jun 18, 2003 | 03:06 PM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't try Redline... I've heard too many bad things about it... try GM Syncromesh synthetic.... heard nothing but good things about it.</TD></TR></TABLE>
My tranny already is fucked, or at least the syncros. Why not give it a whirl, if I can shift without grinding 3rd at 4K rpms with Redline MTL, I'm using Redline... Ya' dig?
Old Jun 18, 2003 | 03:11 PM
Default Re: 3rd gear problems?? (superls92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superls92 &raquo;</TD></TR><TR><TD CLASS="quote">where can you get syncros from any were on the internet?? </TD></TR></TABLE>
ttt
stevevang
Apr 14, 2014 02:47 PM
kungura
Honda S2000
16
Jun 27, 2005 08:44 PM
cvc323
Jul 29, 2004 03:07 PM
cxSHOE
14
Dec 30, 2003 06:14 PM
b00stn
Oct 25, 2002 02:22 PM
