What else can I swap from an SI Civic to a DX Civic?
Like the title says, would like to know what else can I use from the my SI, I already took the engine, tranny, harness, p28 computer, gauge cluster, interior. is there anything else I can use from the SI to make my DX better, like suspension ect... or any other thing that the DX didn't came with. Im about to say by to my SI but will like to know what else I can take out.
thanks in advance.
thanks in advance.
front brakes, suspension (if it has less miles than the dx), sway bars, brake booster, master cylinder, taillights, spoiler, center dash console with side a/c controls, front bumper, fenders, headlights, hood, grille
Re: What else can I swap from an SI Civic to a DX Civic? (EL Vap133)
I have the rear trailing with the rear disc set up already. Front brakes well its the same size as my DX, maybe because I have a 92, they told me that 94-95 have the front upgrade brakes. I have the brake booster, master cylinder and propoltion valve. are the SI shocks any diffrent thatn the DX?
also don't know this for a fact yet but I belived that the SI didn't come with power windows. I already have the full interior out. Someone mention the front and rear swaybars I just have to figure out how to take those out.
anything else guys?
anything else guys?
I check my SI and it doesn't have rear sway bar, is this an upgrade for the the later years 94-95 ones? I belived it has a front one Im almost sure that I saw one. Now are all SI come with sway bar or this is a EX coupe and sedan thing?
Ok, I have the brake booster and the proportion valve, but if everything on the SI and DX reads the same, should I change it anyway? Also the brakes if the caliper and everything else is the same do I have to change it?
I'm taking everything apart like I did with the rear trailing arms, Im putting new rotors, bolts, lug nuts, pads, lines,fluids and I'm painting everything.
I just don't want to go thru all the hassle of taking stuff apart that I don't need. My car being a 93 SI came with all disc brakes, but the front are the same sizes as the rear. I belived 92-93 came like that. I belived my DX front rotor came with the same size as the SI. Can anyone verify this info, I just want to put everything together already and don' waste any time.
Re: What else can I swap from an SI Civic to a DX Civic? (Boricuanology)
People are getting confused on which Si you have. Put which year you have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boricuanology »</TD></TR><TR><TD CLASS="quote">I check my SI and it doesn't have rear sway bar, is this an upgrade for the the later years 94-95 ones? I belived it has a front one Im almost sure that I saw one. Now are all SI come with sway bar or this is a EX coupe and sedan thing?</TD></TR></TABLE>
1999-2000 civic si's came with the sway bars. Once again people don't know which si you have.
Read this for the brake info. No better info on Honda-Tech.
https://honda-tech.com/zerothread/1811368
efracer
03-21-2005 02:45 PM
ryan12321
11
12-06-2002 09:04 AM
