tranny helppp!
Old 02-28-2008, 05:12 AM
ej1 assasin's Avatar
Default tranny helppp!
just blew the clutch ad transmission on my eg(sohc zc). just got a new tranny and stg1 exedy clutch do i need to have the transmission in a certain rotaition spot or do i just put that hoe on? and the trany i bought i took the casing off to look at all the gears just to make sure before i put it on, now what kind of gasket sealer would be the best to use to seal it up? thnx.
Old 02-28-2008, 05:17 AM
z6hatchboy's Avatar
Default Re: tranny helppp! (ej1 assasin)
There should be two dowels on the motors that the tranny slides onto, thats all there is to that part (besides making sure the clutch disc is centered for the input shaft). Use honda-bond ($12 a tube) for the gasket material on the tranny, anywhere .
Old 02-28-2008, 05:20 AM
got it..thanks
Old 02-28-2008, 05:25 AM
whats the easiest way to get the oil pan sensor out?
Old 02-28-2008, 09:56 AM
blk92_d16's Avatar
Permatex Grey is practically the same and cheaper. The clutch pkg should come with an alignment tool...use it!
Oil pan sensor? The only thing on a factory Civic oil pan is the drain bolt...
Old 02-28-2008, 10:05 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
man...when I first read your thread, I thought you were a tranny who needed help.
Then I find out that you needed help with your transmission...and you MAY or MAY NOT be a tranny. What a rip off.
Anyway, just make sure that the splines line up (duh). Dont jiggle the trans up and down. Rotate the trans slightly to make the splines line up. Then re-rotate it back into the correct position. There will be dowel pins for alignment.
Now...are you a tranny or not?
Old 02-28-2008, 12:52 PM
blk92_d16's Avatar
^He drives a 5th gen coupe, definitely not. LOL
Old 02-28-2008, 01:07 PM
1992Si's Avatar
The hard part is getting the clutch lined up the first time.
tip; I use the long motor mount bolts to hold the tranny aligned with the block and clutch. Then replace with the tranny bolts as I get the tranny close to the block.
Old 03-01-2008, 06:39 PM
Default Re: (1992Si)
thnx all is much appreciated.
tbonez
08-27-2007 06:04 PM
TurBoXBirD16
06-30-2002 11:32 AM
Replica_Racer
06-21-2002 02:26 PM
Replica_Racer
06-20-2002 09:42 PM
hybridcrx
03-13-2002 08:41 AM
Quick Reply: tranny helppp!
