D16Z6 Swap into EG
D16Z6 Swap into EG
Hey guys, I just recently finished swapping a D16Z6 into my 92 EG CX. I'm using the stock CX wiring harness. After the swap I have two unknown wires left. I was just hoping if you guys could identify these wires for me and tell me where they go,
The pigtail and the four wire, my friend did most of the unplugging while I was stuck unbolting stuff so now he doesn't remember where it went. The pigtail fits into the vtec oil pressure switch pretty well but I'm pretty sure that that's not its original place. Any help is great, thanks
Modified by fizik at 4:56 PM 3/1/2008
Mr. Badwrench
Re: D16Z6 Swap into EG (fizik)
the round eyelet is your harness ground. goes to tstat housing, the other appears to be your fan switch. about 98% sure. because it is so close to the ground.
Re: D16Z6 Swap into EG (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">the round eyelet is your harness ground. goes to tstat housing, the other appears to be your fan switch. about 98% sure. because it is so close to the ground.</TD></TR></TABLE>
sparxx
17
08-26-2005 04:20 PM
