tps problem!
tps problem!
my tps harness clip was came off of the tps while i was driving today and it made my car stutter at 4.5
after that happened it threw code 7, i pulled over to a park and i plugged the clip back it but then it still threw the code. then i went to my friend's house so i can change my tps since i had an extra. changed it,but the code is still there and now my idle sits at 2k.
does any1 know what it could be?
the motor is a 96 gsr in a 92 si
Re: tps problem! (eg_boi)
you will need to adjust the tps to the correct voltage range...i dont have the full instructions...but you should be able to find it on our "Archived content"
found a link: https://honda-tech.com/zerothread?id=2318158
ludacole
08-13-2005 11:59 PM
smokinsi
07-18-2004 05:09 PM
