Tire Rub
Tire Rub
i want to get 205/50/15 falken anzenis for my Eg hatch, stock suspenion, but i want to lower it, will they rub, and should i go for like a 195?
thanks
thanks
Re: Tire Rub (XpodX)
many people have gotten the 205 15's with out a problem....if you want to play it safe go with the 195's....but you should be fine with a 205
Re: Tire Rub (FifthGearOnline.com)
There are a few issues with tire rub. Some people's camber goes off more than others. I have a 2.75" drop on my car with just 205/40/17 and they rubbed in the rear hardcore. Then i got the camber kit and they rubbed even more. There are two options that you can do. The cheapest of the two is rolling the fenders, they just take the flat part of your fender near the wheel, and roll it up so theres more entry space. The second route is the one that I did, SPC rear lower control arm, tucks it in half an inch. Its great now, haven't had a problem with rubbing since. Good luck.
Re: Tire Rub (99eciVic)
That's good info. I recently installed 205/50/15 Azenis on my EG and they rub a bit (front and back). Where might I find a good price on the SPC LCA's?
The wheel offset is the most important factor... then how much you're planning on lowering it.
I'm running the 205-15 Azenis on 15x6.5 +40 wheels with no problem. I've still got about a finger and half gap to the fender (big fingers). If you go too high on the offset, say +45, then you're in danger of rubbing on the upper control arm. If you go too low, say +38, then you're in danger of rubbing on the fender.
Re: Tire Rub (iviZeRoCooLivi)
o found some new tires ever hear of em Ziex 502 & Ziex 512 195/50HR15 82H ZIEX ZE-512 FALKEN $68.50
there 195 so they should be good right
ZylexSNL has the Falken 512's right now....and i should be getting mine tomarrow or wed. and those tires have insane WET and DRY traction.... ill give you a full review of them in a few days...
but from what i have heard they 512's are supposed to have a little better ride then the 502's. Also if you are looking for a good performing all season performance tire...the 512's actually have a very mild mud and snow rating because of some small lines they made in the tires
last thing...the 512's are the newer of the two tires
Re: Tire Rub (fastguy)
My 18's only rub alittle, and that is with my cut springs. The trick is that you can remove the plastic lining crap and hammer some of the metal out of the way.
im getting these, i heard they are very good
http://www.tirerack.com/tires/Compar...peed_rating=ZR
hahah thats a huge link, well they are Kumho
ECSTA Supra 712, 50 bucks on the tire rack, 195/50-15
dose anyone think i will run into problems?
did you search? cause i replied to like 203985324 ones of these questions...ehehe, once again you shouldn't, depends on the offset, and if it does, you can roll fenderes...
johnnieh93
01-15-2010 07:09 AM
danny98r
05-25-2005 07:38 AM
