Lowered sol with 15's and 205/50/15 rubbing
Yep. That's bout it. Fenders rolled too. Twin s tech springs which doesn't has an extreme drop.
Tried 195/55/15 didn't work at all.
Tried 205/50/15 and still rubs. I think I need a different offset or a 15x6. Any ideas?
O. Z. CRONO HT
15x7
Offset: 37mm
Backspacing: 5.51"
Bolt Pattern: 4-100
Rec. Tire Size:195/55-15
Weight: 13.5lbs.
O. Z. CRONO HT
15x7
Offset: 37mm
Backspacing: 5.51"
Bolt Pattern: 4-100
Weight: 13.5lbs.
Re: Lowered sol with 15's and 205/50/15 rubbing
if you have camber at all it shouldnt rub. i run 205/45/16 toyos on my wheels and they have a 35mm offset. i only rub on BIG bumps. im also dropped 2.5-3" and not rolled.
post up some pics.
post up some pics.
It rubs on the outer fender still on bumps. Don't have a camera right now. I was thinking I can just get some different springs to bring it up a very little bit or some coilovers. These tein springs are pretty old not too sure if the tension is correct.also anyone know a place that can modify the wheels offset? Correctly?
Also it is all four corners on bumps. Tried adjusting camber negative but still not completely gone. Doesn't rub as bad but still does.
redGSRguy
10-19-2006 12:31 PM
danny98r
05-25-2005 07:38 AM
CeoStatus0
10
07-25-2004 12:27 PM
