Timing Belt Help
Timing Belt Help
I drive a '98 Hatchback (cx), purchased the car used 2 years ago and have done all the work on it myself. The engine is stock, no mods, and has apx. 105 thousand miles. I don't know if the owner before me replaced the timing belt or not. How do I do a visual inspection of the belt?
thanks
Modified by kryptonite67 at 8:20 PM 1/15/2006
thanks
Guest
Posts: n/a
Re: Timing Belt Help (kryptonite67)
timing belt intervals are 60-75k depending on engine type and location (weather)
see what the spec is for service intervals on your timing belt. If your really nervous about it, just change it. it is deffinatly insurance, and it's not the difficult to change
Re: Timing Belt Help (95DxSi-R2)
i figured that would be the right thing to do anyway... i was just trying to prolong doing the job in order to avoid the bolt on the crank pulley. thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kryptonite67 »</TD></TR><TR><TD CLASS="quote">i figured that would be the right thing to do anyway... i was just trying to prolong doing the job in order to avoid the bolt on the crank pulley. thanks guys.</TD></TR></TABLE>
Ya if you plan on changing it yourself just go ahead and do it. The bolt on the crank pulley isn't hard, just make sure you have a huge breaker bar and a long pole.
