whinning after t belt replaced
so just replaced the timing belt the oter day now it has a whinning noise around 1800-2500 rpm i am thinking it is the timing belt to tight but i am kinda confused on how to adjust it. i know there is a bolt that sticks out from the cover but idk what to do with that loosen it then tightin it or what.
H-T Order of Merit
Re: whinning after t belt replaced
yes, it sounds like the timing belt is too tight.
To adjust the timing belt tension, first position piston No.1 at TDC. Then loosen the adjusting nut 2/3-1 turn, rotate the crankshaft counterclockwise 3-TEETH on the CAMSHAFT and retighten the adjusting nut.
Mine started doing this too.
I suspected that it was the Tbelt but how would it tighten itself??
It just started a few weeks ago but i changed the belt in july.
slide inside
10-22-2009 09:25 AM
