Ticking Sound from Head between 1000-1200rpm
Old 04-16-2018, 02:52 AM
Anthonyeckhard's Avatar
Default Ticking Sound from Head between 1000-1200rpm
There's a ticking noise comming from my Head
Cant really place what it might be
Link to video
https://youtu.be/fn-gj0n13c8
It starts around 1100 rpm above 1500 there's no ticking. Its a d15z6 block with a d16z6 Head. Want to Turbo it but not before this is solved
On the video its less noticable
Any1?
Old 04-16-2018, 03:28 AM
holmesnmanny's Avatar
Default Re: Ticking Sound from Head between 1000-1200rpm
sounds like exhaust rattle, but could be an exhaust leak, when the exhaust has a leak it's noisy because noise escapes out
you can try seafoaming the intake and looking for white seafoam smoke leaking out of the exhaust there
Old 04-16-2018, 05:24 AM
Aint the exhaust since it really Comes from inside the engine
Sounds like there's something loose in it but we checked and there isnt so that's the problem.
Think I Have to buy a new head
Old 04-16-2018, 05:56 AM
compression test it to see if the engine is in good
you can always hand crank the engine with the valve cover off and see if something is loose before messing with the head
Old 04-16-2018, 06:01 AM
Did already check for loose things. May be doing a new compression test tomorrow
Sqni
03-07-2019 01:39 PM
ih8speedbumps
01-04-2014 03:17 AM
Fook_me_honda
05-12-2007 11:24 AM
mcgee*
01-05-2006 12:14 PM
SamC
10-21-2003 08:02 AM
Quick Reply: Ticking Sound from Head between 1000-1200rpm
