Thermostat not opening and lines have extreme pressure.
So I know there is a million threads online and on here that deal with this and I promise you I have dug through everyone of them and I am still stumped.
So here's my situation I have a 2000 civic with a b16 swap with P30 pistons and minor head work. This motor has given me problems here and there but they were always things that I was able to troubleshoot and fix. But I have been stumped on this.
A month ago I was driving and noticed the car was getting hot I immediately cut it off before it even got 3/4 on the gauge. Popped the hood and noticed both hoses were swollen and couldn't even squeeze them, yet the lower hose felt was cold but had a lot of pressure. My first thought by me and others was the thermostat. So I get that changed out after a while because I never have time. Got the lines bled and all drove it and never got over operating temperature. But I popped the hood and the lines felt the exact same lower was cold and had a lot of pressure so clearly the thermostat wasn't opening again. I thought maybe I got that rare bad OEM thermostat, I know it's rare but it happens. I exchanged it out and did the same process again. Again same thing happened with lower hose being cold. So this time I did a compression test and checked for signs of blown head gasket. There is no white smoke, no oil and coolant mix and the compression numbers were 209-207-210-209 from what I could read on my shitty gauge. That made me believe the head gasket is fine until I was bleeding the system today and noticed when I give it and gas at all the coolant neck begins to bubble almost like a boiling pot looks, no exhaust smell at all just a subtle bubbling of the coolant and the the coolant level goes down. I know a blown head gasket can cause exhaust in the coolant lines but why would I have no other effects what so ever and good compression numbers?
Also before this the car did feel some what sluggish but the distributor was fried and just replaced that bit haven't had a chance to drive it since but it was running better after the replacement of the dizzy.
Any ideas to try would be greatly appreciated.
Thanks
Thanks
Cool Cool Island Breezes. BOY-EE
Re: Thermostat not opening and lines have extreme pressure.
^the compression test was good. So...not likely a completely cracked sleeve.
OP...maybe the radiator is clogged. Did you use tap water or cheap coolant?
Once the hoses stretch, will they ever be the same?
If you've bled the cooling system properly and you still get bubbles with the rad cap off, that's an almost sure fire sign your Head Gasket (HG) is no longer doing it's job.
To be absolutely sure you have exhaust gas coming through your rad, spend 30 bucks on a block tester and fluid. If the blue fluid turns yellow, you have a leak, whether it's a cracked head or block or just the head gasket, you won't know until you pull the head and look around. Some cracks are not easily visible to the naked eye and so you'd know by just changing the HG and still fail the block test.
This is what a block tester kit looks like:
This one is a bit more but is a dual chamber to eliminate false positives. You can get the regular single chamber with fluid for about 30 bucks.
Before I get my sleeved block, I have a similar problem that ended in a hair line on the top of 2-3 sleeve.
This is what a block tester kit looks like: Amazon.com: UVIEW 560000 Combustion Leak Tester: Automotive
From what I've noticed it is only when it's warm never really tried to give it gas before it warmed up so I can't say for sure. Only thing with the water pump idea is the thermostat does open when I'm bleeding the system with cap off. It's only when I drive the car that I get all the pressure which is why I've leaned towards a cracked head or bad head gasket. Still waiting on a time to do the leak down test and/or the coolant test to start eliminating more things.
Retired Moderator
i wouldnt waste time/$$ doing a leakdown..If it raises when your giving it gas then its either a HG or something more.
Pulling the head will give you a better look. use that leakdown $$ for a new HG and headwork.
If you're not getting bubbles when the car is cold and you are blipping the throttle the headgasket is probably ok. The reason you're getting bubbles when it is warm is there is no pressure in the system and the temperature in the head is hot enough for the water to boil. That is normal. If you were losing coolant after driving it for a bit that would also be a sign of a headgasket. I didn't see you mention if you were losing coolant. If you have one hose hot and one cold you need to know why coolant isn't circulating.
I had the bubbling + pressure issue before, and at the time, everyone seemed to tell me that I had a HG problem. Turns out I had an air bubble in my system due to me having forgotten to turn on the heater when filling the radiator. I only got the issue when the cold days started, because I had not turned on the heater before that.
When you last filled your coolant, did you jack the front of the car up as high as you can using a regular jack and make sure that your heater was turned on? Also, make sure you drain everything out (including the block) when you do that. It could be the HG or pump, but I would also check if the coolant was filled properly.
mrbsponge
10-15-2006 06:16 AM
RCautoworks
Welding / Fabrication
06-02-2006 08:01 AM
