temp guage and gas guage not working
i have a 92 hatch wit a d16 and last week i had to change my starter and ever seens i changed my starter my temp guage and gas gauge have stoped working..ive already checked my fuses and still nothing wat should i do???
Re: temp guage and gas guage not working (RonJ@HT)
i changed my fuse and my gas guage started working but my temp gauge still isnt working.wat else do u think it can be
Re: temp guage and gas guage not working (joshluis)
The temperature sending unit (one wire) is located below the distributor and next to the temperature sensor (two wire). With the ignition key ON, disconnect the sending unit and short the wire leading to the gauge against a metallic part of the engine. If the temperature in the dash gauge rises, it is fine and the temperature sending unit likely needs to be replaced. If the temperature in the dash gauge does not rise, then the gauge needs to be replaced.
thanks bro i fixed it the problem was dat the wire was cut for some reason but its working now...by any chance do u kno wat i can do if the lights in my dash or the a/c council are not working i already checked the fuses but there all good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshluis »</TD></TR><TR><TD CLASS="quote">thanks bro i fixed it the problem was dat the wire was cut for some reason but its working now...by any chance do u kno wat i can do if the lights in my dash or the a/c council are not working i already checked the fuses but there all good</TD></TR></TABLE>
Troubleshoot the Dashlight Brightness Controller:
sexyblack973
23
08-15-2013 10:51 AM
specie
08-01-2010 01:59 AM
4g4db16
10
10-13-2007 01:50 AM
SlimBB4
04-21-2007 12:08 PM
