Tach question
Tach question
i know that obd2a motors get their tach signal from the distributor.
where does obd2b motors get their signal?
i just put a obd2b motor in to my obd2a car. i rewired the distributor using obd2b plugs. i just need to figure out how to get the tach working.
well what im saying is the 96-98 has a 9pin distributor plug(the extra wire is the tach signal). however the 99-00 has a 8pin. it missing the tach signal wire that the 96-98 has. ist gotta get it from somewhere else then.
you can find a signal wire by the driver side firewall look for a baby blue with black stripe wire i believe i had the exact same issue someone correct me if im wrong.
Re: (mv1luv)
yeah not sure about the newer civics but on EG's its a baby blue wire you can find either on the insider driver side of the firewall, outside driverside of the firewall, and on the distributor
Tyson
40
06-04-2009 04:24 PM
