tach is not working ** look inside**
Hey hondatech Iam having a problem with my tach, its not reading the rpms!
The lights work and everything else works fine, can someone tell me wich wire i can run str8 from the dizzy to my cluster?
btw its the second cluster ive tried!
oh and its a gsr with a dx harness into a vtec cabin harness lol
thanks any suggestions will help
there should be a black and blue wire on the dizzy that are fat. It's the blue one, on the dizzy. and as for the cluster, I have no idea. Try an after market tach to see if it gets a reading??? I had the problem where my tach would sometimes work and it would sometimes not work. My problem was that my dash harness was burnt out because the stupid *** dealer used the wrong fuse and i shorted something and blah blah. Long story short, the smoke inside of my car scared the fukc out of me.
Re: (Hanmin)
Black/yellow wire= power to coil, blue fat wire=tach signal wire from coil. Coil is grounded to dizzy is grounded to engine... I think thats how the ground is...
Re: (skUnK2jdm)
I don't know if hard wiring the factory tach is a good idea... Just buy and inexspensive<sp? tach from advance or something. More than likely you have a problem with the gauge itself anyways.
vtechjunkie
28
03-16-2010 11:14 AM
honda_boy23
04-14-2009 08:47 PM
EF'IN NUTS
03-27-2004 08:53 AM
