fuel pump not turning on
Re: fuel pump not turning on (redferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redferio »</TD></TR><TR><TD CLASS="quote">no spark no fuel ..pump is not turning on...need help asap
check the main relay.
Re: (lshatch98)
I checked the main relay...switch dizzy, ecu, main relay, fuel pump..i checked all the grounds....
I forgot to mention that the ecu fuse kept poppoing until i found the one ground lose by the fan swtich...
Modified by redferio at 6:49 PM 9/17/2008
Re: (-[95cxhatch]-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -[95cxhatch »</TD></TR><TR><TD CLASS="quote">-]how did you check the main relay? it really sounds like your main relay is bad...</TD></TR></TABLE>
93 civic coupe ex..
i switched it..
93 civic coupe ex..
i switched it..
Re: fuel pump not turning on (SwapsRUs93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapsRUs93 »</TD></TR><TR><TD CLASS="quote">do u have a check engiine lite on and if it is does it just stay on all the time?</TD></TR></TABLE>
yes it does.....9 and 10 are the codes
is your transmission ground wire hooked up ? if it is not then your car will not start, and nothing will turn on besides the headlights wipers and radio
Re: (redferio)
try using another ecu, i had the same problem. i replaced all these parts and it just turned out that the ECU went bad. so you should try.
Re: (Roi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Roi »</TD></TR><TR><TD CLASS="quote">try using another ecu, i had the same problem. i replaced all these parts and it just turned out that the ECU went bad. so you should try.</TD></TR></TABLE>
I did that already....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -[95cxhatch »</TD></TR><TR><TD CLASS="quote">-]9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
Check the wires/grounds for these...</TD></TR></TABLE>
I'll try that today
I'll try that today
i got the fuel pump going and the main relay...it was the ground on the tranny that was no good....now i have no spark.....dizzy is brand new from dist. king
Phil McConkey
02-25-2007 07:42 PM
boosted_soul_94
08-05-2006 09:57 AM
DenMatic
21
02-03-2004 05:51 PM
