Swapped a Ported head on my d16z6... won't start.. bad timing maybe
Old 07-29-2004, 11:13 PM
EGcivicBoy's Avatar
Default Swapped a Ported head on my d16z6... won't start.. bad timing maybe
This post is for my friend...
Just swapped a used Ported and polished head on my d16z6 and hooked everything up and it wont fire..
Everything is conected, and i think i did the timing right from my manual.
When i try to turn the motor over with the key it makes a ZInggy noise comming from the distributor.
The number #2 spark plug wire is broken alittle, but shouldnt the motor still start?
We have triple checked the timing and even tried it 180 degrees more.
Please help asap
Old 07-30-2004, 12:23 AM
EGcivicBoy's Avatar
Default Re: Swapped a Ported head on my d16z6... won't start.. bad timing maybe (EGcivicBoy)
We checked TDC, lined up all marks according to manual.
Like i said before distributor makes a Zingging noise when cracking over. Timing belt moves, but there is still no compression.
We have tried everything and now asking the world of Honda Tech so i don't have to go to a shop
Thanks
Old 07-30-2004, 12:43 AM
menkio's Avatar
well, i would make a list of all the steps you can think of doing with swapping the head. list the diffrences on a sheet of paper as well. Then go down the list and inspect each with detail.
Old 07-30-2004, 12:51 AM
EGcivicBoy's Avatar
Default Re: Swapped a Ported head on my d16z6... won't start.. bad timing maybe (DewMota)
We have gone over everything many times. Noone has ever had a problem like this??
Old 10-21-2004, 09:24 AM
menkio's Avatar
i wonder what happened
Old 10-21-2004, 09:25 AM
Luserkid's Avatar
Default Re: Swapped a Ported head on my d16z6... won't start.. bad timing maybe (yanta)
Maybe the distributor crapped out on you? Or just the ignitor?
HondaJDMLife
11-04-2014 07:17 AM
Phil_Civic
11-06-2009 10:30 AM
turboek6
08-25-2008 08:42 AM
thrty8street
33
02-28-2005 03:21 PM
Quick Reply: Swapped a Ported head on my d16z6... won't start.. bad timing maybe
