swaping in Cx Hatch
Old 12-09-2006, 09:48 AM
dreams_of_ek9's Avatar
Default swaping in Eg Cx Hatch
I kno every body is gonna say search, but i have been and havent found the exact answers im looking for the cx. I planning to swap a b18b or b16b in to my hatch, i never swap a motor before. I kno or i think i kno i can use my motor mounts for both swaps, but wat about axels (i think not )? I kno i need the motor, tranny, ecu, but will i need any harnesses? and is there anything im missing?
Modified by dreams_of_ek9 at 11:10 AM 12/9/2006
Old 12-09-2006, 09:52 AM
HT White Ops
Eran's Avatar
you will need a 99-00 si rear tranny mount (firewall side), a CR-V timing belt mount (motor side), axles, half shaft, a full harness from your old motor and your new motor. When we did my LS, we used the stock Y7 harness, extended the secondary O2 sensor, and replaced the entire intake manifold harness with the LS part.
Old 12-09-2006, 09:56 AM
Default Re: (Eran)
i thought the b16 was a drop in? and the ls i could use a mixture of integra and my mounts?
Old 12-09-2006, 09:58 AM
HT White Ops
Eran's Avatar
Default Re: (dreams_of_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the b16 was a drop in? and the ls i could use a mixture or integra and my mounts? </TD></TR></TABLE>
No. You need the mounts I said. You need the 99-00 si rear tranny bracket that mounts to the body of the car for ANY b-series swap into a hatch. And to reuse your driver's side timing belt mount that's on your body, you have to swap out the timing belt mount on the motor for one from a CR-V.
Old 12-09-2006, 10:03 AM
Default Re: (Eran)
ok so wat can i use from my hatch, except for the harness, and the mount? Im kinda on a budget, but if i need all of this i think i might wait and just pay a shop to swap it? i thought if i bought a obd1 sir b16 with all the parts to swap it it would just hook right up.
EK FLY's Avatar
Default Re: (Eran)
WELL WHAT CAR ARE WE TALKING ABOUT 92/95 EG , 96/00 EK ?
well I gess is a ek9
well u will need a complete set of 00 si engine monts if ur car is a 99-00 u will need obd2b jumper harnes to obd1 &lt;---- will make ur life easyer
Old 12-09-2006, 10:05 AM
Default Re: (super-hatch)
94 eg hatch
Old 12-09-2006, 10:06 AM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">94 eg hatch</TD></TR></TABLE>
Well expletive, why did you name yourself "dreams of an ek9" when you have a 5th gen?
expletive this thread.
Old 12-09-2006, 10:07 AM
Default Re: (Eran)
i dreamed of one but i never got it, i didn't say i had one
Old 12-09-2006, 10:09 AM
so wat would i need to swap in a 94 EG CX HATCH?????
Old 12-09-2006, 10:10 AM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">i dreamed of one but i never got it, i didn't say i had one</TD></TR></TABLE>
Rule of thumb:
If some retarded noob with a chassis code in his name asks a question and doesn't say what car he has .... one would assume that he drives a car SIMILAR or EQUAL to his user name.
Guess that went out the window.
Read that.
http://honda-asylum.com/smf/index.php?topic=111.0
Old 12-09-2006, 10:15 AM
Default Re: (Eran)
ok thanks for the note, but do u kno or don't???
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for the note, but do u kno or don't??? </TD></TR></TABLE>
RETARD.
Read the link. It tells you what you need.
Old 12-09-2006, 10:17 AM
Default Re: (Eran)
Thanks
HiProfile's Avatar
Default Re: swaping in Eg Cx Hatch (dreams_of_ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams_of_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">I kno every body is gonna say search, but i have been and havent found the exact answers im looking for the cx.
Modified by dreams_of_ek9 at 11:10 AM 12/9/2006</TD></TR></TABLE>
How about this - you suck at searching? This info is so common, you can find this info scrawled on public restroom doors.
Old 12-09-2006, 10:19 AM
Default Re: swaping in Eg Cx Hatch (HiProfile)
ok.... so i guess let the flaming begin
jamesb!
09-27-2009 11:43 PM
Dasfinc
01-09-2008 11:33 AM
WhiteOnRice
33
10-09-2007 05:50 PM
phatboi
01-07-2005 03:21 AM
Red Civic T
12-06-2001 09:20 AM
Quick Reply: swaping in Cx Hatch
