Swap a VX tranny into a del sol si ?
I have a 93 del sol si and would like to swap in a CIVIC VX transmission. Will this work? My goal is to get better gas mileage, plus I drove a VX before and I liked how 1st gear is a lot taller, so that traffic wouldn't be as much a pain to drive.
Pros/Cons?
If not, anyone want to buy a Civic VX tranny?
Thanks.
Pros/Cons?
Thanks.
Re: Swap a VX tranny into a del sol si ? (tadaima)
If you want it for gas then sure itll be fine. Throw it on and enjoy the low RPMs.
Just dont floor the gas or your just wasting gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tadaima »</TD></TR><TR><TD CLASS="quote">Well I assume it will perform better then the VX (in terms of acceleration)</TD></TR></TABLE>
u are true, but u need the right driveline to get the power to the ground in the right manner.
u can also find vx trannys for hella cheap, sence people want the ex/si trannys. u can sell the tranny u have now for like 150-300 shipped if its in perfect working order. (no grinds, or noisy bearings)
Re: Swap a VX tranny into a del sol si ? (Vtecin94dx)
i would not suggest it. this is my own personal preferance though. i have a 95 vx...completely stock. the gas mileage is ok, but if you want your car to accelerate at all, don't get it. again, just personal preferance.
plus, i don't really think the gearing is helping my gas mileage any. my friend has a 95 si that is stock, and we both get about the same mpg. but its completely up to you.
Re: Swap a VX tranny into a del sol si ? (ninefivehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninefivehatch »</TD></TR><TR><TD CLASS="quote">i would not suggest it. this is my own personal preferance though. i have a 95 vx...completely stock. the gas mileage is ok, but if you want your car to accelerate at all, don't get it. again, just personal preferance.
plus, i don't really think the gearing is helping my gas mileage any. my friend has a 95 si that is stock, and we both get about the same mpg. but its completely up to you.</TD></TR></TABLE>
has your vx been kept up with the maintence, like the fuelfilter, plugs, and what not. maybe thats why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">
has your vx been kept up with the maintence, like the fuelfilter, plugs, and what not. maybe thats why.</TD></TR></TABLE>
true. i have kept up on oil changes, but as far as i know, it is on the original fuel filter, wire, etc. i think i will look into that tomorrow!
For economic purpose, then yes.
Longer gear ratio do give better gas mileage. Example: Your are crusing on the freeway (VX) 3,000rpm @81mph, (SI/EX) 3,000rpm @ 74mph.
The higher you rev the more it take gas. Those number should be accurate, since i swap a si tranny to vx motor.
Re: Swap a VX tranny into a del sol si ? (kaiba)
My 93 del sol runs 3,000rpms at 65mph. I remember the VX needed to drop to at least 4th gear to do any usable acceleration, and would expect the same effect when switching the tranny, but i would feel that since the d16z6 (ex.si) engine is at least 25hp stronger, that the acceleration wouldnt totally suck at 1-3rd gear.
Re: Swap a VX tranny into a del sol si ? (DJ_SaNdOz)
downgrading your transmision? for what reason?
ex/si has shortest gear and is the best tranny for the D series in terms of performance..
i guess if u want your car to be slower/better gas you can put a the vx tranny in..
but why not just keep the ex/si trany and just shift under 3.. ur gas should be good.. i know gas is expensive but no sense to downgrade performance for like 2 mpg imo
edit- didnt see u already had it /// selll it n get the ex/si tran
Re: Swap a VX tranny into a del sol si ? (i3lazedx)
DJ_SaNdOz: Thanks, that helps a lot. Looks like I should expect a +4mpg. I generally (normal driving) shift between 2500rpms - 3000rpms.
i3lazedx: Reason for my change is for gas mileage and to have better usability of each gear in traffic. I get pretty tired shifting from 1st to 2nd in 0-30mph traffic. Driving the VX, showed me that I can hold onto 1st gear a bit longer, or have a wider range on 2nd gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tadaima »</TD></TR><TR><TD CLASS="quote">DJ_SaNdOz: Thanks, that helps a lot. Looks like I should expect a +4mpg. I generally (normal driving) shift between 2500rpms - 3000rpms.
i3lazedx: Reason for my change is for gas mileage and to have better usability of each gear in traffic. I get pretty tired shifting from 1st to 2nd in 0-30mph traffic. Driving the VX, showed me that I can hold onto 1st gear a bit longer, or have a wider range on 2nd gear.</TD></TR></TABLE>
No Problem. I honestly liked teh 1st/2nd gearing of teh VX better than the EX/Si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">
No Problem. I honestly liked teh 1st/2nd gearing of teh VX better than the EX/Si</TD></TR></TABLE>
i know exactly what you mean haha.
Re: Swap a VX tranny into a del sol si ? (Chris M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M »</TD></TR><TR><TD CLASS="quote">i thought the del sol si had a b16 in it?</TD></TR></TABLE>
not for the earlier ones i believe. the earlier ones had a z6 someone correct me if i am wrong.
Re: Swap a VX tranny into a del sol si ? (_OEM_)
Damn, well I guess we all learn something new every day. I always though that the Del Sol Si's had the b16a3. So now I take it those things must be pretty rare then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M »</TD></TR><TR><TD CLASS="quote">Damn, well I guess we all learn something new every day. I always though that the Del Sol Si's had the b16a3. So now I take it those things must be pretty rare then?</TD></TR></TABLE>
they are pretty rear, every Si sol i have seen has had a d16z6 in it, and for some reason most of them were automatic too,
krysted9354
11-23-2008 11:48 AM
Charlie Moua
01-06-2006 10:31 AM
