The stubborn coilover lock screw, need tips!
Old 11-01-2005, 04:22 PM
BDogggUT34's Avatar
Default The stubborn coilover lock screw, need tips!
I bought the car with GC on them already, dont know how long they've been on. Since winter is coming i wanted to raise the car up a tad. But i cant seem to get 3 of the 4 lock screws on the bottom perch to budge. Any suggestions??? I tried to use WD-40 and let it sit but there isnt much space for it to penetrate and loosen. Probly dumb question, but the lock nut is still righty tighty lefty lucie right?? Lol, just makin sure its not a special situation screw.
Old 11-01-2005, 04:25 PM
Stoich EG2's Avatar
Default Re: The stubborn coilover lock screw, need tips! (BDogggUT34)
turn the hex screw counter-clockwise
Old 11-01-2005, 04:26 PM
BDogggUT34's Avatar
Default Re: The stubborn coilover lock screw, need tips! (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">turn the hex screw counter-clockwise</TD></TR></TABLE>
ok thought so, but wont budge!! Broke a few allen wrenches in the process
Old 11-02-2005, 08:05 AM
BDogggUT34's Avatar
any suggestions??!! this is probly the same for any stuck bolt
Old 11-02-2005, 08:18 AM
O RLY's Avatar
You need to find a bar that will fit the adjustment wrench's end. Hopefully you have two of them. Position the coilover so that you can wedge one of the wrenches in between the lock nut and the frame of the car, so that its snug. Then take your other wrench and fit it onto the lock nut, using the bar you found for torque. I'm not sure if we're on the same page here, but if we are, that's how I adjust my Skunk2 coilovers when they've been corroded for a while.
Old 11-02-2005, 10:08 AM
Hatchoo's Avatar
Default Re: The stubborn coilover lock screw, need tips! (JDMH22Civic)
Whoa, I've got the same problem. Trying to raise the ride for winter too. Bent a few allen wrenches and threaded the d@mn screw.
https://honda-tech.com/zerothread?id=1420177
Now I'm looking around. Good luck.
Old 11-02-2005, 06:43 PM
BDogggUT34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22Civic &raquo;</TD></TR><TR><TD CLASS="quote">You need to find a bar that will fit the adjustment wrench's end. Hopefully you have two of them. Position the coilover so that you can wedge one of the wrenches in between the lock nut and the frame of the car, so that its snug. Then take your other wrench and fit it onto the lock nut, using the bar you found for torque. I'm not sure if we're on the same page here, but if we are, that's how I adjust my Skunk2 coilovers when they've been corroded for a while. </TD></TR></TABLE>
i actually do understand what you are saying, but these are GC and have an allen wrench screw that tightens to hold on bottom perch. Not like the Skunk2's that have two bottom perches that tighten against each other to stay.
TB123
Suspension & Brakes
03-11-2008 02:56 PM
kuja396
15
06-03-2007 10:18 AM
Nicram
10
04-27-2007 07:26 AM
kevoweb
08-11-2005 07:48 PM
ch4nq
53
02-09-2005 02:36 PM
Quick Reply: The stubborn coilover lock screw, need tips!
