Strange Knocking while decellerating. Not brakes.
Any one know what this is? The knocking/thumping only happens when I am slowing down. It doesn't seem to be break related, and no difference when I am turning.
Axels? Joints? Tranny? Operator?
Thanks for any information any one can provide!
Re: (Turbo E)
check your torque mounts... same thing happened to me. The passengerside was the one giving me noise with all the bolts missing. Took me about 6 months to figure it out.
Re: Strange Knocking while decellerating. Not brakes. (knoj)
After I first did my swap, I also noticed a loud noise that would only happed on decelleration, it turned out to be the bolt where you connect the ground strap on the valve cover, it was catching on my worn *** hood everytime I slowed down, check under your hood and see if anything is catching,
I know it is kind of out there, but it did happed to me....
Re: Strange Knocking while decellerating. Not brakes. (92b18cx)
It could be this, what's this fella called?
Jacked up the car, wheel won't shake, motor won't shake. Yes I engine brake, but even in neutral when I idle, I still get the thumping when I am slowing down, not exhaust. Breaking is smooth, and clean. Nothing dragging below.
Drivers side, by my feet, I can feel the thumping.
Think this is it? What is the thing in the picture called exactly?
Trans brace? There's no context with the picture, and I'm an EG guy, so thats just a guess.
-dave
-dave
Re: Strange Knocking while decellerating. Not brakes. (dpaton)
Context: What is this? It looks twisted and busted, and squished, and cracked, and worn, and...
I hope this is it... I can take better pictures if you need. The one on the passenger side looks better.
B20 swap was done before I got the car. Some half-*** work was done... But the price was right.
Re: Strange Knocking while decellerating. Not brakes. (Bcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">Replace it and see what you get.</TD></TR></TABLE>
Wish I knew what part to order?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knoj »</TD></TR><TR><TD CLASS="quote">
Wish I knew what part to order?</TD></TR></TABLE>
Engine side lower mount.
Re: (Whig-it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whig-it »</TD></TR><TR><TD CLASS="quote">it is a torque mount. it hooks to the frame, and tot he a/c mount</TD></TR></TABLE>
bazing baby what did i tell you... driver side torque mount
Re: (knoj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knoj »</TD></TR><TR><TD CLASS="quote">Thanks fellas, looking to find one now...</TD></TR></TABLE>
ES engine mount inserts would fix that right up... Along with the other two torque mounts. ~$35 also.
Re: (mike1114)
Ordered... Should be in Monday. Not sure if that is the problem though... Seems to go along with axel speed... I guess I'll find out right? Hope the ones for the Si will work for an EK with a B20
alscrx
29
08-10-2021 11:23 PM
EG6lovin06
10-03-2013 01:15 PM
oskar_0709
03-25-2011 11:13 AM
Ming Tsai
09-22-2006 09:05 AM
