Loud knocking noise from passenger wheel well.?
ok just as the title stats... there is this clink-clank noise from the passenger side wheel well when I drive on bumpy surfaces. The road whould have to be brand newly paved smooth to not hear the noise. Sounds alot like something is not bolted tight enough and loose, a clink and clank knocking sound.
anyways, i assumed it was the axle.. so I replaced that... still makes that noise. My friend said it could be loose breaks or it could be my steering knuckle.
anyone out there got any insight on this... I need to isolate the problem.. thanks guys.
Re: Loud knocking noise from passenger wheel well.? (Ming Tsai)
Probably a suspension piece. Maybe a balljoint. There's only 10,000 possibilities based on the discription you gave us.
Re: (Evs-One)
sounds like what my girlfriends nissan was doing, pass. rear hub bearing was shot. slid it off and it fell to pieces. only has 30,000 miles on it, i love honda
Re: (ridin98civic)
I will bet you 50 bucks it is your upper strut mount.
leave the car on the ground and tighten the strut bolt. If not, your strut is blown.
Re: (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">I will bet you 50 bucks it is your upper strut mount.
leave the car on the ground and tighten the strut bolt. If not, your strut is blown.</TD></TR></TABLE>
hmmm... that might be it.. my brother told me his friend had the same problem and it was a loose strut bolt. I'm gonna have to check that after work.. hopefully it isn't a blown strut.
dopesk8er87
27
04-09-2013 07:51 PM
jayare05
11-25-2012 08:21 AM
