stock turbo mainfild fits ex coupe d16z6?
ok i have never looked at turboing a z6 for accords i know there is a dsm manifold out there that fits just need to modify it a lil is there the same for a z6 just wondering
Re: stock turbo mainfild fits ex coupe d16z6? (n20_b1tch)
The HF manifold will bolt up. I think all you have to do is make/get an adpater plate to bolt up a turbo.
You should check out homemadeturbo.com
There's a really comprhensive write up on turboing a d-series.
Re: stock turbo mainfild fits ex coupe d16z6? (highroller54)
You should really start researching before you just start jumping into a turbo set-up. I would check out homemadeturbo.com and also turbod16.com to help ya out, very good information on both of these sites. Good luck!
Re: stock turbo mainfild fits ex coupe d16z6? (Ej1_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe »</TD></TR><TR><TD CLASS="quote">You should really start researching before you just start jumping into a turbo set-up. I would check out homemadeturbo.com and also turbod16.com to help ya out, very good information on both of these sites. Good luck! </TD></TR></TABLE>
Re: stock turbo mainfild fits ex coupe d16z6? (92vx-t)
i just wanted to know how all these guyz are turboing their cars for cheap cuh i have a d16z6 i am building and i read sum guy did his for 500 bucks i looked around all i saw was 500 for exhaust manifolds..........where do i get the adapter plate? if its too expensive i can fabricate parts also know how to weld
Re: (blkhatch92)
I'll sell you my turbo kit for $700 plus shipping it's a DSM T-25, 2G o2 housing w/ custom downpipe, custom 2g ic piping, 2g bov, 1g ic, cx manifold, bmc race adapter plate, DSM 450cc injectors w/ clips and capacitors, and an A'PEXi V-AFC II.
Going LS/VTEC
Going LS/VTEC
Re: (92vx-t)
I just need to get rid of it so that I can buy a new tranny for the LS/VTEC. The V-AFC is only about 6 months old and 4 of those months the motor has been blown so it's just sat in the car. I paid almost $300 for that alone.
Re: (redhondacivic)
how much play in the turbo? piping....miles on turbo..........miles u had it for...fit a stock z6? expletive with emissons? im in cali 926562.........isnt the mitsu turbos small? and they go to like 8psi right?
Re: (n20_b1tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n20_b1tch »</TD></TR><TR><TD CLASS="quote">how much play in the turbo? piping....miles on turbo..........miles u had it for...fit a stock z6? expletive with emissons? im in cali 926562.........isnt the mitsu turbos small? and they go to like 8psi right?</TD></TR></TABLE>
VERY VERY VERY little shaft play, piping is basically the stock piping off of a 97 GSX that was modified to fit my car, the car had 90k on it when I pulled the turbo I put about 3k on it and it was owned by an old lady so never rode hard, of course it will fit, thats what I had it on. Probably won't pass emissions, just pass the car, then put the turbo on. It is a fairly small turbo but thats good because you will have full boost (8 psi) at about 3K. Yes the stock wastegate is set to 8 psi but I have seen these things run 19.
Shipping would be between $35-50 depending on weight and the box size.
JDMroyEG5turbo
04-15-2006 08:29 AM
