Losing clutch pedal
Losing clutch pedal
I have a 97 Civic and my master cylinder went bad. Changed it, bled lines and drive it for a couple days before I lost the pedal again. Changed slave cylinder, bled lines, and again a couple days go by, lost the pedal. Disconnected the lines again, cleaned them, re installed, bled lines fixed for a couple days. Now I have to bleed the system to get to work, it holds just enough to get me home at the end of the day. I have no leaks and the reservoir doesn't lose fluid. What do I do now?
i use to have a similar problem and couldn't find a leak, i change master and slave cylinder bleed it ran fine then started to loose the pedal again, later i found out it was the rubber section of the clutch line right by the tranny that was leaking, there was a small breakage on the bottom side that was slowly leaking away, not saying it could be that but you might want to check if that is the case.
autoxthis
Transmission & Drivetrain
09-18-2008 12:50 PM
RTW DC2R
07-17-2008 06:29 PM
Duck Sauce
04-13-2008 09:30 PM
