starting problem
Old Jan 31, 2008 | 05:29 PM
h22-hatch's Avatar
Default starting problem
alright guys...
i know this is a civic thread but i need help on my 5th gen prelude...the car will not start!!!
im getting fuel, spark, timing is right.....i have NOT ran a compression test due to the fact i dont have a tester...
i have replaced plugs, wires, cap, button, coil, ICM...tried jump starting it...tried spraying fuel in the IM...
i dont know what else to do...please give me some more ideas to try...i need to get this running...
Old Jan 31, 2008 | 05:39 PM
corked1260's Avatar
what happened when u sprayed fuel into the IM?
Old Jan 31, 2008 | 05:48 PM
h22-hatch's Avatar
Default Re: (corked1260)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corked1260 &raquo;</TD></TR><TR><TD CLASS="quote">what happened when u sprayed fuel into the IM? </TD></TR></TABLE>
nothing....same ole crank....
Old Jan 31, 2008 | 06:09 PM
corked1260's Avatar
well if it did at least run until it birned off the fuel you dumped in i woud think u dont have spark..... how did u test for it?
Old Jan 31, 2008 | 06:44 PM
hondatuning1989's Avatar
same happened with my buddies d series in his hatch we tried everything finally did a compression check afer changing head gaskets 3 times...guess what...read 0 in all 4 cylinders....try thet
Old Jan 31, 2008 | 08:32 PM
watsvtecEK's Avatar
Default Re: (hondatuning1989)
If you sprayed fuel into the intake manifold and it did not pop then you ether have no spark or no compression.
Old Feb 1, 2008 | 04:39 AM
h22-hatch's Avatar
Default Re: (watsvtecEK)
well obviously yall cant read...i DO have spark...pull a plug stick it in the plug wire ground it and watch the bitch spark...im running a compression test later on today...hopefully i blew the damn thing up lol
Old Feb 2, 2008 | 01:30 PM
h22-hatch's Avatar
Default Re: (h22-hatch)
cylinder 1- 110 psi
cylinder 2- 70 psi
cylinder 3- 140 psi
cylinder 4- 130 psi
i have spark!!! come on guys i know somebody knows something to try!!!
duhafnusa4
Mar 19, 2008 05:35 PM
knomexx
Jul 14, 2005 08:13 AM
EKB18BPR3
Nov 23, 2004 12:43 PM
EckoTech
Oct 30, 2004 01:25 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
