please help
Old Mar 17, 2008 | 07:27 PM
duhafnusa4's Avatar
Default WTF please help
ok heres the problem
did a compression test
didnt know to unhook the ecu fuse
coil fried
put in a new one
car still wont start
checked for spark:there
checked for fuel:there
air definatly there
it sounds like it has a low bettery but i jumped it and still wont start
BTW its a 94 gsr w/ a B16a2 init
please help me get this fixed
Old Mar 17, 2008 | 07:33 PM
lmike6453's Avatar
it's pro flooded with fuel
Old Mar 17, 2008 | 07:44 PM
all-mtr-teg's Avatar
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">it's pro flooded with fuel</TD></TR></TABLE>
Yup, pull a spark plug and check to see if the tip is covered in gas
Old Mar 17, 2008 | 07:48 PM
HmgLauj69's Avatar
yup happen to me before, pull the plugs and let it dry
Old Mar 17, 2008 | 07:49 PM
duhafnusa4's Avatar
Default Re: (all-mtr-teg)
you can def. smell the gas on um, but last night i let it sit w/ out the plugs in to evaporate all the fuel
ill do it again tonight and try starting it in the morning, u think thats all that it is? flooded?
Modified by duhafnusa4 at 8:33 AM 3/18/2008
Old Mar 17, 2008 | 08:26 PM
james_ls's Avatar
Sounds flooded.
Heres hoping...you have all the necessary items to make it run...
Old Mar 17, 2008 | 08:34 PM
Default Re: (duhafnusa4)
You can also use compressed air to help speed up the process.
Old Mar 18, 2008 | 06:59 PM
duhafnusa4's Avatar
nope didnt work, its w/ the dizzy somewhere
Old Mar 18, 2008 | 07:18 PM
denraweb's Avatar
If you have spark, it isn't your dizzy. Are you sure you have the wires correct? Also where did you check for spark? At the dizzy? Or at the spark plugs? Also how did you check for fuel? One other obvious thing...do you have gas in your tank? Can you hear the fuel pump priming?
Old Mar 18, 2008 | 07:36 PM
duhafnusa4's Avatar
Default Re: (denraweb)
checked at the plugs
i think my ing. mod. is bad.
have fuel, 1/2 a tank, u can smell it on the plugs as well
new problem
turned it on all the way untill before u accually try to start the car(where u check for cels) and i heard a buzzing sound i went to check it out in the engine bay and there was smoke!! WTF i took my batttery out and i know its either a wire of fuse cuz the smell but cannot find the source
Old Mar 18, 2008 | 08:34 PM
Buzzing noise if probably your abs, assuming you have abs. Check to see if you have spark if not, probably fried your coil or module.
Old Mar 19, 2008 | 05:35 PM
duhafnusa4's Avatar
wuaf wuaf wuaf its worked tonight i need a new dizzy, getting one tomorrow!
woot woot thanks everybody
SonyaE
Sep 23, 2008 04:00 PM
h22-hatch
Feb 2, 2008 01:30 PM
raiden571
Jul 9, 2007 08:11 PM
ek4ferrio
Jun 3, 2007 02:59 PM
SpoolinEK
Dec 10, 2003 02:28 PM
