Starting an engine thats been in storage for 2yrs
My car is a 98 civic dx. I bought a '00 civic ex (d16y8) engine to put in my car about 2 yrs ago. Lots of **** has happened but its finally time to install it. The '00 engine only has 15k miles on it. Its in mint condition. However, its been stored in a garage for the last year or so. The first yr it was in a temp controlled storage unit.
What kind of precautions do I need to take before I turn the key once its installed?
Doesnt matter, but I have the ex tranny for the new engine too that will be installed with it.
Re: Starting an engine thats been in storage for 2yrs (AGENT 99)
i would change oil then disconnect ecu fuse and crank the motor up about 10cranks to get oil pressure up then put the fuse back in and start it up.
Re: Starting an engine thats been in storage for 2yrs (UNKNOWN_MEMBER)
I'd see if u can get it to run on stand (not sure if it's like a V8 in the fact that u can run it on stand) but I'd actually buy a whole gasket kit and do all the gaskets, pistons rings...etc. **** dry rots after awhile :-\ Might run fine now, might blow a ring 20 miles from now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 »</TD></TR><TR><TD CLASS="quote">
Doesnt matter, but I have the ex tranny for the new engine too that will be installed with it.</TD></TR></TABLE>
I would change the oil immediately to make sure no condensation was in there. Other than that the rings should be fine, they may take a few rotations to seat again, but I wouldn't worry about it shitting parts on the interstate.
Re: Starting an engine thats been in storage for 2yrs (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- »</TD></TR><TR><TD CLASS="quote">I would change the oil immediately to make sure no condensation was in there. Other than that the rings should be fine, they may take a few rotations to seat again, but I wouldn't worry about it shitting parts on the interstate.</TD></TR></TABLE>
God that would suck.
Yeah I'll swap some oil and check a few gaskets. What do you think about putting a little oil in the spark plug holes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGENT 99 »</TD></TR><TR><TD CLASS="quote">up for some help on this.</TD></TR></TABLE>
some JDM swap have been sitting for many years in japanese junkyards, it should be fine once you swap the oil
Re: Starting an engine thats been in storage for 2yrs (Sleepy_Red_hatch)
You should change the sparkplugs, cap and rotor while you're at it. You can start your maintenance records ... g'luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
some JDM swap have been sitting for many years in japanese junkyards, it should be fine once you swap the oil</TD></TR></TABLE>
This is true. Makes me feel better about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBOOSTER »</TD></TR><TR><TD CLASS="quote">You should change the sparkplugs, cap and rotor while you're at it. You can start your maintenance records ... g'luck</TD></TR></TABLE>
I will. Plugs, cap, rotor, and I'll drop the oil pan and clean it out just to be sure theres no gunk.
Any more advice before I do this? My current engine is EATING oil like a **** and my current tranny sounds horrible. (I have a new trans to go in too)
SalsaGuy
02-06-2016 05:51 AM
EJ8_Enthusiast
25
08-26-2008 09:57 AM
QuickStyle
05-03-2007 10:24 AM
