SRS light
SRS light
got a 00 civic the srs light is on and the steering wheel is completely off..last owner said he was in a hurry and half-assed the install. and my horn doesnt work either...anyways to reset the srs light im also taking off the steering wheel to make the it straight
Re: (94allmotor)
depends what year the car is, if it has dual or single airbag
dual airbag there will be a yellow plug connector that plugs into the underdash fuse box... it plugs into a dummy connector. you need a jumper or paper clip to conect to the end to reset. there are certain timed steps u will need to take.
or single airbag, the reset connector will be on the opposite side, which is your passanger side. it will be plug again to a dummy connector. again there are certain timed steps u will need to take.
certain timed steps: ie: srs light blinks, etc
Re: (MOB: Jeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOB: Jeff »</TD></TR><TR><TD CLASS="quote">depends what year the car is, if it has dual or single airbag
certain timed steps: ie: srs light blinks, etc</TD></TR></TABLE>
i got a 00 civic ...timed steps?
Re: (94allmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor »</TD></TR><TR><TD CLASS="quote">
i got a 00 civic ...timed steps?</TD></TR></TABLE>
theres srs procedures
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94allmotor »</TD></TR><TR><TD CLASS="quote">that would disbale the airbags?</TD></TR></TABLE>
in order to disable the airbags, unplug the battery. wait at aleast about 5 min. get a torx screw driver, one on each side remove airbag. passenger side if u need too. to disable the airbags, you need to completely take out the whole srs system. shown here.
remove srs light in cluster.....remove this piece off of cluster.
thewrai6th
01-15-2009 05:28 PM
